Gas gauge inaccuracy
#41
Originally Posted by SargentZ
I've noticed this on my 07. I filled her up, ran it down till the low fuel light came on, said I had 39 miles left. It took 16 gallons to fill it back up. So the Z has a 4 gallon reserve? I calculated a 22 MPG average so technically I should have had 88 miles left. hmmm, better having more than less left I guess
bill
#42
on
Today I was on the freeway and my gas tank light came on and the computer thing said I had like 18 miles of fuel left. In reality, I had at least 100 more miles of gas, and the entire time I was on the freeway with cruise control on. After about 10 minutes it went up to a quarter tank...from empty. WTF is that all about?
#43
#45
on
Originally Posted by Zmazing03
From my experience, Nissans have weird gas gauges. Both my step moms Altima (2006), her old Maxima (1999), and my Z (2003), they all have the same gas gauge "issues". It tends to take forever to go from Full to 1/2 tank, but once you get to 1/2 tank it falls to E at least 40% faster than when I was going down to 1/2. Annoying, but I have noticed this in all three of the cars.
#46
Well, I got my car back and so far so good. They gave it back to me with a half a tank. The DTE read 235. They replaced the Dual Tanks said there must have been a vacuum issue in one of the tank, the Air Bypass Valve and the Fuel Pump. They asked me to drive it till she's empty and then fill her up making sure I can put 18-19 gallons of fuel. I'm so happy to have my car back, I even gave it a present yesterday. A JWT PopCharger.
#47
on
DTE will drop from 30 to zero after engine restart when my tank is low.
Originally Posted by ray427
Gas gauge reads about 1/4 tank, i fill up with 9 gallons. anyone hae this problem before. ALSO, does anyone use the dte gauge and if so how accurate would you rate it?
2003 touring 6 speed
#48
on
The DTE is based upon ongoing computation of your miles per gallon. If you are sitting idling it is simply telling you that you will go no miles before you run out, which is the truth if you stay there idling. It will take sitting awhile if you haven't reset anything as it computes from previous use. Even when not idling, it will go --.-- normally when you have 1.5-2 gallons of the final (hidden) reserve left. I say 'hidden' as it is there even though the dial gauge says empty, the low fuel light is on, and the dte computer shows --.-- miles left.
The issue with the air by-pass valve and the sensor are different issues and there was a tech bulletin ref to this on prior years models. If you are having a problem, there are several threads on this issue and a "search" will reduce your worrying or at least point you in the right direction.
#50
on
my o6 z has no guage problems but my fuel pump sceams a high pitch noise all the time like an old t.v. set-took it to nissan several times they say they can not hear it! gives my wife and I a head ache on any trips longer than 30 miles-any help would be great
#51
on
But don't test it to find out how many miles you *really* have. If you fill up with about 16, that's normal.
#52
on
Whenever i fill up my tank it will never go to full the most i ever put in was about 12-14gallons max. When my gas light comes up the DTE goes on at like 30dte then goes back up to 45 after happening 4times all you see is ------- this sucks my honda never had this problem. but hey its a 350z love the car
#53
I have owned a few Z cars over the years, an 87 300zx and a 93 300zx, I now own a 03 350z and each car has had the same type of gas problem. The gas gauge would say empty with the reserve light on and when you would fill it up the tank would only hold about 12 gallons. Thats proof that Nissan has had this problem throughout the years. Personally, it doesn't bother me that much because I usually fill the car up when the light comes on anyway. But this problem has been known by Nissan for a number of years and it still amazes me that Nissan doesn't do anything about it.
#54
on
Where can I find the Technical Service Bulletin and what does it mean for me if I am OUT of warranty??
Last night I could only fill up with about 12.5 gallons and this has been a consistent problem for me for a while now.
#58
on
it might be the pump. I filled up at Sams the other night and my z wouldn't take more than a half of tank, even after starting over. I have not had this issue at any other stations. weird....
#59
on
Gas Gauge only reas 3/4 filled up
It looks as if I'm not the only one in this boat. Nissan replaced both sending units, one in each tank yesterday and the problem is still there. I had to thrash them though, they only put 5 gallons in and called and said the gauge was working. I was like duh, it always did work. It just never went to full when you filled it up, common sense to me says, hey I should fill the car up and see what the gauge does. I guess were just smarter then the guys nissan pays to work on are cars for us. If anyone happens to find a DIY to fix this issue that would be great.
Nate
Nate
#60
did you replace teh shutter valve too?
It's not the pump. Here is an easy way to see if it works. WHen I had the problem, my car would not go past the F mark like a normal gauge. As soon as my problem was fixed, I can go past F when I fill it up.
