ART test pipes on backorder for 2-4 weeks?
#81
you will be okay, but i would get it when you can
its where you tuck the bumper..........
https://my350z.com/forum/9619022-post1.html
But you have to friggin' drill through the bumper? ...I won't be able to watch
#86
#88
cat brace.... which obviously she doesn't have, and i would highly recommend getting it. it helps keep the art pipe from twisting side to side thus helping limit the possibility of cracking. later on when you get tuned, remove the anti foulers, because they can adjust that afr to where you don't need them, or even turn off the sensors (but they still read available to the ecu)
I don't have mine that should have come with the car. I've searched the Internet, Craigslist, Amazon... Only place I could even find ONE was Ebay and it was for an 04. Will this fit my 06? Better yet, do you know if a muffler shop can create one?
#91
Not yet they will be installed on Tuesday. Here is a clip of the hks exhaust with the current Titek pipes. I'm hoping the ART pipes will improve on the tone.
https://m.youtube.com/watch?v=64Nw4hX794Y
Different angle...
Honestly though, the video sound doesn't do it justice. It sounds way better in person. .... and yes, I know I shift slow, I'm working on it lol ... Be kind!
#93
work that stick, bae
#94
Exhaust tone after ART pipe installation.... video quality is kinda crappy cause it was getting dark
https://m.youtube.com/watch?v=TtRMm_mAEsc
Different angle...
https://m.youtube.com/watch?v=669g96SgznY
Different angle...
You shift fine, do you ever drive in heels? I have a really hard time driving in anything other than tennis shoes or barefoot. FOr some reason the clutch on my car is ENGAGED or NOT...no slight buffer lol
#97
There's a little bit of rattling going on under the driver's seat right about the area where the art sits. Any idea what that could be? Happens at about 3k rpm and seems to get a bit worse as the car heats up. Doesn't do it all the time but often enough.
#98
heat shields?
#99
Yep, took it to the shop... The set up is such a tight fit that the heat shield on drivers side didn't have enough clearance. Dude took the flat end of the crowbar and rubber mallet and banged the heat shield a few times giving it about another 1"... Problem solved
