Buying/Leasing 350Z/370Z Purchasing Info
2006 Z, what are things to look out for when buying used?
Old 08-25-2014, 03:15 PM
2006ZCar
2006ZCar's Avatar
Default 2006 Z, what are things to look out for when buying used?
Hi,
I'm looking at a 2006 350z, are there anythings to look out for when buying used?
In the 2003-09 model, where there any bad years to buy or better 'versions'?
It has around 50K on it.
Old 08-25-2014, 03:18 PM
travlee
Master
travlee's Avatar
Received 9,046 Likes on 6,512 Posts
06 have the revup motor which is known for oil consumption, not too hard of a fix if you feel comfortable doing it
i would go for a 07 or 08, they have the HR motor
Old 08-25-2014, 03:27 PM
oldschool350z
oldschool350z's Avatar
I would never buy a 2006 because of the rev up engine.
Old 08-25-2014, 03:30 PM
oldschool350z
I feel stupid lol because I bought a 2004.5. I wish I got the HR instead of the DE. But I got my Z years ago and couldn't afford a 2007-2008.
Old 08-25-2014, 04:58 PM
2006ZCar
2006ZCar's Avatar
What exactly is the diff. between the revup and HR? what does that stand far?
thanks for the tips!
Old 08-25-2014, 05:33 PM
375rngrZ
375rngrZ's Avatar
im going to list out the extent of my knowledge to educate you lol.
03-05 DE:transmission synchro issues most people wait for theirs to go out and upgrade to a cd009
master cylinder issue, its a cheap fix but a pain in the *** because it comes out of nowhere
base models don't have hid lights or vlsd, not a problem but hindsight I really wish I had both of these lol
window motor issues, people have been known to go through 2-3 motors its an easy fix but trust me is a pain in the ***
power steering pump failure, cheap fix, this one seems to be less common but none the less I ran into it.
05-06 rev-up: oil consumption is the biggest problem ive seen with these someone people report having no issues but the majority seem to have it.
much lower torque figures, they changed the plenum to give it a little boost in hp which resulted in less torque not really a problem but something worth knowing.
window motor problem , its across the board in all 350z models.
my understanding is these transmissions have a csc problem which is kind of a pain in the *** considering im pretty sure you have to drop the tranny to get to it, I may be wrong someone with a newer model might be able to clarify this.
07-08 HR: has the best engine in my eyes its got the dual intake setup and much stronger internals then the previous two engines which if you plan on boosting later on will make a big difference.
ive heard of some oil consumption issues but they are few and far between.
the god forsaken window motor again.
and ive heard of some csc problems which again can be a pain to fix.
honestly I have an DE and hindsight I really wish I would of spent the extra cash to get an HR. I love my DE but for the extra money you get HID headlights, a better tranny, a vlsd, an engine with stronger internals for boosting, the LED taillights (I don't like em but they seem to be popular), and more power granted its not much but in a vq especially N/A ones every little bit counts.
EDIT: just learned that all 3 base models come with an open differential. just as a side note.
Old 08-25-2014, 06:17 PM
Nismo350z#0310
Nismo350z#0310's Avatar
Well, IMO, things to look out for are 2006 Zs. Lolol
But seriously, I'd try to find a good deal on HR or an 04-05 DE.
Old 08-25-2014, 06:35 PM
RUNWDVL
RUNWDVL's Avatar
I would buy an HR. Don't care how great a deal a revup is unless doing engine swap.
Old 08-25-2014, 10:48 PM
NiLL
NiLL's Avatar
06 Has speed sensitive steering, is MONSTROUSLY cheaper to mod then an HR, has a a few interior trim parts that are better looking, and most people freak out over the "oil consumption" of the rev up. I own one and so do 2 friends of mine, no consumption.
Im sure there are a few cars that have this issue due to people not having it fixed under warrenty, but people on this forum blow this issue way out of proportion. HRs are nice but if you are looking to do work on it expect to pay a ton more. It's also a lot more expensive right now to buy a used 2007-08
Old 08-25-2014, 11:55 PM
375rngrZ
375rngrZ's Avatar
if your looking for cheap to mod you minds well keep shopping and never look at the z again.
Old 08-26-2014, 12:22 AM
mr_shnuffles
mr_shnuffles's Avatar
If your planning on boosting it (turbos or supercharger) definitely get one with a HR motor. The DE motors can't handle must boost. I've seen broken rods at only 7.5psi on De motors and I know a couple people running 11-12psi and putting down over 600rwhp on stock HR motors. If I knew this before I bought my 350z I would have saved the extra.
Old 08-26-2014, 03:27 AM
jdmlove1
jdmlove1's Avatar
one of the cleanest 06 350z are for sale now.. it belong to the forum member Sry.. check the for sale section
Old 08-26-2014, 03:38 AM
travlee
Master
travlee's Avatar
they arent that much more to mod, just the intakes and cats, other than that almost everything is the same as the de. i am putting down about 30 more hp than my buddies with equally modded DEs.......
Old 08-26-2014, 04:12 AM
Nismo350z#0310
Cheaper to mod? Not all at.
And the revups aren't going to get as much gains as an HR on those mods.
Old 08-26-2014, 04:14 AM
Nismo350z#0310
I've never seen an HR making 600whp on stock internals, but I'm thinking of trying for it
Old 08-27-2014, 05:13 AM
Everet Hampton
Everet Hampton's Avatar
I have an 06. I have done 3 track days with it in the last 6 months. I change the oil before and after no oil consumption. I've read about it, but never seen it. My friend also has an 06 and tracks his. No problems.
Like buying any used car, look it over with a fine tooth comb. Remember you are buying a used car. USED CAR.
08-06-2021 06:19 AM
3vilbunny
07-18-2017 05:10 PM
Fixxxercask
11-09-2015 11:10 AM
_bit
10-02-2015 07:49 AM
Quick Reply: 2006 Z, what are things to look out for when buying used?
