door not shutting flush?
on
On the other end of the door, nearest the front of the car, is it flush there, or raised as well? Is the end you photographed he only part that's not sitting flush? Did any of the disassembly involve the striker plate in the door sill?
I ask because I had occasion to replace one of my doors and have some familiarity with the issue.
on
I believe it will end up being the striker plate.....but first try removing the striker plate and carefully pushing the door closed to see if it will shut with no interference (watch the paint). If it closes flush without the striker plate in, smooth and with no interference, that's the problem.
on
Photos of the door seals, under the door, along the edge, the door sill and jamb please. We're all gonna kick ourselves for easy of a fix this will turn out to be.
Here's a video of everything,
As you can see everything is lined up and where it needs to be.. I literally have no idea why it's not shutting right.
<iframe width="420" height="315" src="//www.youtube.com/embed/9CHxs5FbkIQ" frameborder="0" allowfullscreen></iframe>
on
How about those fasteners along the top edge of the rocker panel? Could those be standing proud enough to inhibit full closure? Maybe it's the angle of the video, but I'd more closely examine the relationship between the aft end of the rocker and the door sill…..maybe it's off there.
are you talking about the rivets in the side skirt?
The side skirt and the rivets holding it in were never touched during the whole process and the door closed flush before.
maybe the striker is bent or something?
could it be something to do with the door handle?
i've tried everything.... so frustrating..
MAsSIVrOOM
10-20-2023 10:50 AM
