could use some help
on
could use some help
2003 base 350z, when I put the car in gear (mostly 2nd and 4th) it seems like when I accelerate it skips or leaps. It happens every once in a while but I have no idea what it is. Any ideas?
1st..3rd...5th....6th.
You don't really need all 6 gears. You can get by with 4. And if you wind out 3rd long enough, you can skip 5th and go directly to 6th. Winning!
on
sounds like driveline problem. I think you should check you mounts and bushings. Look at transmission mount, engine mounts, and subframe bushings. especially the differential to subframe bushings. Good luck.
