How to tell the differences in 350z diffs, without the car?
Old 10-20-2014, 07:26 AM
chintzelman
chintzelman's Avatar
Default How to tell the differences in 350z diffs, without the car?
Is there a way to tell what type of 350z diff one is, without the car. Is it stamped on the pumpkin? If I remove the cover, will the final drive ratio be engraved or molded in the gear or somewhere? I plan on buying a VLSD, but the OP is unsure if its originally from an auto or a manual. I don't want an auto final drive. I tried google this but all I found was diff ratios with the model and trim level they come stock with. I know a stock manual is 3.5, and I believe a stock auto is 3.3.
Sum:
Can I look at a diff and find out what its final drive ratio is?
Old 10-20-2014, 12:15 PM
ShineMaster
ShineMaster's Avatar
Question
Sum:
I would also like to know this! Subscribed.
Old 10-20-2014, 12:17 PM
92K1500
92K1500's Avatar
I'm 99% sure the pumpkin itself is the same between them. The gear ratios are different and if you're going from an open diff to VLSD the stub shafts are different.
Old 10-20-2014, 09:37 PM
mr. sparco
mr. sparco's Avatar
5AT: 3 bolt propeller shaft flange.
6sp: 4 bolt propeller shaft flange.
Old 10-21-2014, 02:03 AM
R3belzBRN
R3belzBRN's Avatar
Gb: 5at Vsld differential
GD: 6mt vsld
Gc: 6mt open diff.
Check the words painted on the pumpkin
Old 10-21-2014, 05:46 AM
chintzelman
OK... but is the ratio written somewhere? I would like to see if its a 3.3, 3.5.. ect
Old 10-21-2014, 05:50 AM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
I believe that's on the later chassis (370, G37) I've done many sets of diff bushings and only seen pics of the 3 bolt setup.
Old 10-21-2014, 06:56 AM
R3belzBRN
R3belzBRN's Avatar
Obviously all 5at (GB marking)comes with 3.3 and All 6mt (gc and GD marking) comes with 3.5.
Old 10-21-2014, 07:11 AM
Jennifer 2
Jennifer 2's Avatar
If you wanted to confirm the ratio, why couldn’t you just turn the input shaft and carefully count the number of turns of the axle shaft?
lolwatbro
10-09-2021 04:58 AM
davidm350
10-31-2015 02:28 PM
rizzla
Drag
09-17-2015 08:44 AM
RyansZ33
09-15-2015 05:54 AM
3vilbunny
09-13-2015 12:31 PM
Quick Reply: How to tell the differences in 350z diffs, without the car?
