2004 Nissan 350z N/A build
on
you don't have much H.P so no need for AFTERMARKET LSD
Need some advice for the next stage .What'd be the most reasonable combination for my current setup, -3.9 final drive + quaife ATB Lsd ??...or may be 4.0 + Final drives and some other LSD like cusco etc....Know there are many of similar threads but i'm still hesitating ... Car has to be streetable ,good for drag racing and track....thats why i thought about this (3.9 final drive + quaife ATB Lsd ) combi...So what r your thoughts, guys ?
on
Hey Tommy ) shifting RpM :7500,rear tires 256/45/18 (but it's temporary u know ))) as for the low hp, u know its never enough ) but ... Even on good tires I never have good grip from the start if I exceed 2000 rpm and spend almost 2 gears slipping...I was told it's all about factory lsd that causes only one wheel spinning
on
IF
If you go on www.youtube.com & look up andre12031948, you'll find 2 of my old videos. One was of my tach where you can see my 7,500 rpm shifts but with smaller wheels/tires. You'll notice that when I crossed the finish line my RPM was only at 7,000 so I changed to 4:08 and I crossed at 7,500 my shifting points and ideal to do.
It's called in the blink of an eye. I learned how to shift when I was very young. I could actually press clutch(stiffer springs pressure plate) shift pop clutch in a blink of your eyes. For real !!!
on
If you can shift a DE that high 7,500 rpm then with those size tires you need at least a 4:08 gear set.
on
try this
You should limit that practice cause it's not really good for the transmission.
As far as mods, driving well is the BEST mod Can't do that, mods will be a waste of money and time... Good luck...
With your tires & shifting at 7,500 rpm 4:08 is the way to go....
on
With the engine OFF and you're parked try practicing shifting. Tap the clutch and ALMOST at the same time (as fast as you can) smash the stick down into second, try to be in second before that clutch pedal comes back up I know that sounds impossible but that's how I learned. Third the same thing but DON'T think JUST go STRAIGHT UP, it will go into 3rd cause your hand will slightly move away from your body and going straight up will really end up going a BIT to the right. As far as getting into first while going into third that is hard to do ????
on
friend of mine has quiafe diff...and its just amazing....cornering are fantastic.probably my very next mod
hardkicks
09-20-2015 12:28 PM
EnjukuRacing
09-11-2015 08:30 AM
