New 350z owner, having a few problems
I just picked up my 2005 touring 350z a couple days ago and so far I have been very pleased with it. It's even better than I thought it would be haha. However I have noticed a couple things from driving it around the past few days which has made me concerned.
The biggest issue I noticed was a loud squeaky sound (I think it's from one of the belts) which I haven't been able to find out what causes it, but I believe it has something to do with the AC. Although I have noticed it when the AC was off, especially when braking or turning.
The second issue is the PSI warning keeps on blinking even after I filled every tire to at least 32 PSI.
The last time I was driving it turned the car off while I was waiting for someone and I heard a clicking sound from the middle/rear of the car. It would click about ever second or two, and eventually went away after 5 or so minutes.
Also for this last "problem" I might be looking for problems where there are none, but I just wanted to make sure I didn't damage the car. There was a big uneven bump in the road which was impossible to avoid, so I went slowly over it and I heard a terrible screeching/grinding sound from underneath the car. Shortly after I smelled gasoline (could've been just me) but that quickly went away. Do you guys think this damaged the car in anyway?
Do you guys have any suggestions as to what I should do or what the problem may be for these problems?
Thanks.
Thanks.
General & DIY Moderator
Welcome- the problems you list a pretty run-of-the-mill. First, the squeeling sound you hear is probably just the drive belt being too loose. Either adjust or replace it (depending on mileage; should have been done at 60K) and use the DIY section on here to learn how. The second issue with your TPMS is likely one or more of the TPMS units in your tires have gone kaput and you'll need to replace them. Try going to your local tire store and see if they can "read" the TPMS units and see which ones are defective. They cannot be repaired, only replaced. Finally, you should probably learn to work on your own car to check on whether or not you screwed something up. Jack the car up and support it on jackstands before you crawl underneath and look around. Who knows? Maybe you damaged something important, but whatever it is, you'll be able to better diagnose it than asking on an internet board.
Thanks for the replies. I'll take a look again tomorrow. I'm still working my way around to getting to know the 350z so I posted these problems to see if these were common problems. Which apparently the squeaky belt, clicking, and PSI being off are all common problems. The thing I was really worried about was the grinding noise after that bump. I've never driven a car this low before so I was really worried I might've hit something underneath the car. Could a hit against a somewhat high bump cause significant damage? I'm not sure what that gasoline smell was, but I didn't see a leak or anything like that. Also the drive after the bump was just as it was before, no sounds or anything. Maybe I'm just overreacting since I just got the car haha. Thanks again.
on
My Z was squealing at start up and first few seconds of movement for a little while. Around this time (December 2014) my brother's G coupe was doing the same. He had his serpentine and AC belts replaced. I had mine adjusted. Problem solved for both of us. He has about 60K miles. I just hit 91K.
on
1 Belt
2 bad sensor
3 exhaust cooling down
4 you have to check but I doubt is something serious specially gas related otherwise you would have a mil with either evap codes or fuel pressure
2 bad sensor
lolwatbro
10-09-2021 04:58 AM
Beater350z
09-09-2015 03:36 PM
