35th anniversary edition or 2007-08 350z
on
I actually Dyno'd my 05 35th Anniversary (Revup) and my 07 HR last saturday. Both is bone stock.
The HR made about 10whp more after 4k rpm to redline.
Torque it made 15-16lbs more from 4000 to redline.
This number would have been even bigger if it was DE vs HR.
there was a correction to the hp numbers (SaE?) from 06-07, the adjusted would have made the revup ~ 292HP i believe, and HR 306. So its really 14more at the flywheel. At the wheels is a little less as I have tested.
The HR feels much better after 4000RPM, it is noticeable, at one point of the Dyno sheet, I had 20lbs ft more torque from 4500-5500. The HR was made to be more happy at higher RPMs it seems. Hope this helps.
To all who commented, thank you for your biased and unbiased input lol...It's great to finally find a thread and links to threads that really go in depth about the engine itself and the differences. I already own a 35th anniversary edition Z, I was just speaking to another Z owner, who had an HR and was stating that basically the HR is leagues ahead of the DE Rev Up, which I found to be slightly unbelievable based on SaE ratings, which probably shouldn't be used to gauge that, but I digress. Regardless, I'm glad that someone dyno'd a stock HR vs a stock DE Rev Up, that's excellent.
Thanks again for your input guys.
OP, I own several variants - DE, HR, and VQ37VHR - and as a counterpoint to all the HR worship (laff) I'm reading, I actually said at one point that the HR is my least loved engine of the three. I've since gotten more acquainted with the HR and do NOT condemn the thing but also don't feel it's the shiznit that everyone makes it out to be.
Of course, I run with stock motors ONLY, preferring to extract the most out of the cars through suspension; so as far as engine mods, cannot say with any degree of accuracy which one is a better base engine to work with. Guess that all depends on the application. Road, maybe the HR, drags, well, chuck it for LSX. Hahahahahaha.
Here, read my comparison of the DE and HR here in this comparison:
https://my350z.com/forum/2003-2009-n...l#post10566715
I'm pretty unbiased about any of my Z cars and prefer to call 'em as I see 'em. (Read the first post in that thread and you'll get a sense that I don't really get all "UP" about a particular vehicle.)
Bottom line, I don't think one can go wrong with any of the three engine series in the Z33 (excluded the VHR because it wasn't available in this generation chassis discussed) SO LONG AS you understand the foibles of each motor, e.g., "06 oil consumption", etc., you should be fine.
Having owned both a DE and 35HR and building and TT'ing both, if your long term plan is to keep the car and eventually potentially go FI and built, the DE is hands down the much easier motor due to the aftermarket support.
The HR still lacks very badly in that area. Engine management options sucks for the HR.
The only cool thing about an HR is taking the 37VHR crank out and dropping it in the 35HR for a small stroker without having to shell out like $5K for the stroker kits. I run a Haltech platinum in my 35HR, but it's not a natively supported setup so it certainly has its own quirks.
If you intend to go all modified, I would say save yourself the potential headache and go DE. A built motor is a built motor and you won't be squabbling about 5 tq difference or any of that crap. Current 35HR is at 640/550 power wise, but, a DE can do that with a proper build; so that's irrelevant, but a DE *IMO can do it more easily with 3rd party support - the HR does certainly feel like the red headed step child in that regard.
VQ35DE / VQ35HR
-cheaper to buy parts for DE
-cheaper to mod the DE
-transmissions don't have the clutch slave issue on the DE
-higher TQ than HR
-more available parts IMO, due to amount of cars in circulation
-kids buy the DE ( due to being cheap )/ doubles as pro since many end up in Junkyards
-DE possible higher insurance due to ^
-Less HP than HR
-crappier interior on the DE ( I dont mind my 05 int)
-general older tech on the DE than the newer platforms
-HR added exhaust VVT
-HR has beefed up engine internals (mainly connecting rods) to hold higher RPM limit
- HR dual intakes remove oxygen starvation from front 2 cylinders ( unless the DE has the P-spacer)
My list may have more ,and to my knowledge is pretty accurate, feel free to correct me.
-higher TQ than HR
-Less HP than HR
I think the main point of this thread is this. OP buy what you can afford. Obviously the newer the car is, the more expensive it will be. IMO buy the newest and lowest mileage Z you can buy. No matter what you get, you will enjoy the Z as it puts a smile on my face, and I am sure everybody on here can agree with that statement.
Now if you are faced with buying an older but lower mileage car vs a newer higher mileage car, use your judgment. The one thing that can be said about all years of the Z is that for a sports car, it is pretty damn reliable.
Just make sure it is clean and meets your needs.
Choice for me was relatively easy..
On the track = 200 lbs of weight means nothing either.
Driver is the most important mod. I have beaten cars that on paper are much faster than me, and have been beaten by cars that on paper are slower than me.
LOL, youve never driven on a track have you? A REAL track, like with turns, Sebring International for example? The simple fact it revs higher, it can hold its breath in the power band and have much faster enter/exit speeds.
I've owned both DE and HR. I have raced and tracked both. HR IS superior in almost every way.
I use to be like many (not all) of the DE owners are, trying to defend it by saying things like "DE has more torque, DE is lighter, Very minimal horsepower difference" but honestly I was wrong.
I loved my 2003 DE when I use to own it. I installed almost every bolt-on on it (headers, test pipes, exhaust, intake, plenum spacer, underdrive pulleys, grounding kit). It was quick, and it sounded mean. I was able to beat many cars including some modded DE Rev-Ups. One day one of my buddies bought an 07 HR (Automatic and STOCK). We lined them up, I took him off the line til about 40mph and then he just flew passed me.
I drive my cars pretty hard (just how they are meant to be driven, they are sports cars). My DE was reliable for the most part, but it did give me 2 main issues. The infamous 3rd gear grind, and towards 100k miles it started giving me oil consumption issues. I owned it for almost 5 years until I sold it.
After, I picked up my current 2008 HR (NISMO). I drive it just as hard, if not harder since I'm doing more track days with it now, and it feels as reliable as the day I bought it. I have owned it for almost 4 years now.
Jumping from a DE, to a Rev-Up, to an HR you WON'T feel much, if any, difference in power because the power delivery in 350Zs in general is very smooth. Seeing your track times and racing others is when you come to realize the better car.
NO year or model 350Z is a bad or worse car. They are all great, no matter which VQ35 model engine is in there, a 350Z is a 350Z. It's just that the HR 350Z is just enough better for me to prefer it over the others.
I will say this though, if you are not going to be tracking your car, or you're just buying a 350Z to generally commute and don't really care to race it, then get the DE. You will save money and they are just as much fun.
MY CARS:
MY CARS:
Between my DE 350 and my 370Z, I was consistently 6 seconds or so faster around Sebring. 2:41 and change in the 370 and 2:47-ish in my DE. My 370 isnt an HR but figure at LEAST 3 seconds faster comparing what the HR (No Shumacher but not newbs either) guys were running.
Drag strip, about 2/10ths of a second faster in my HR but with an almost 5 mph higher trap speed. That's with all the bolt ons on my DE, and stock on my HR.
Around the big track at the Auto Club Speedway in Fontana, Ca. It was a 6.5 second difference. But then again, I do have a NISMO model which is "built for the track". Only suspension mod I had in my DE was the Hotchkis Sport TVS Lowering Kit which was front and rear sway bars and springs. I also put on the NISMO wheels with some pretty meaty Michelin tires for better grip.
#38
I'm just saying people over play how much HP/TQ affect the car's "speed" without factoring weight into the equation. In a drag race yeah you need the shove. However if I can out brake and out corner someone on a more twist circuit the HP advantage goes away. I've been passed by plenty of Miatas that prove this point. Granted I toast them on the straights but their entry and exit speeds are way higher then mine due to the lower weight. In the right hands (not mine I'm a slow poke ) a lighter car has advantages.
No mistake I'd love to have more power ...but you would need to strip the entire interior (and then some?) to save those 200lbs found in the heavier model car. As is the Z is too heavy, but aren't all cars these days?
#39
Toasty
Agreed 110%
Not Sebring which is LONG and fast, but I got plenty laps around Homestead which has lots of short straights and tight turns. You spend all your time there between 30 and 100 MPH
#40
MY CARS:
MY CARS:
First, I want to say, very impressive collection. I've already got a 35th anniversary 350z, I have plans to build the stock motor with forged internals, upgraded rods, and twin turbos. I'm still doing my research to figure out which brands are the best to use and what not, but I'm learning day by day. Thanks for your contribution to the thread, this is all good information!
