Are replacement rubber suspension/differential bushings still available?
I'm looking for replacement bushings like the ones Nismo offered which were hard rubber. So far all I see are urethane and solid spherical.
Anyone still manufacturing suspension/differential bushings made of hard rubber?
Poly bushings are better than rubber bushings. I have the Whiteline bushings in my car and love them.
If your stock bushings are good and just looking for a little more strength, I have the Whiteline inserts if you are interested. PM me.
travlee (10-20-2016)
Yeah I was checking out the urethane ones but I was really just trying to maintain the original stock ride. The poly ones are good on handling but the consensus seems to be the tradeoff is a noisier, harsher ride. Really just looking for an OEM replacement.
6 inch cawk is my fave!
Pretty sure the only way to replace the oem bushings is tp buy a new subframe with the bushings installed from Nissan... Whiteline or energy suspension is about as oem as your going to get without spending big bucks at the stealership.
They dont make any noticeable harshness or noise that I noticed.
