What's the plastic trim around the radiator called
The only things that should be needed is your rad support, side supports (head light brackets) and your bash bar aka silver bumper. As far as brackets and supports go. There isn't anything else up front.
Those are the only brackets and supports that should be up there. Buy yours head light supports from Z1 auto. Used bracket sellers are on crack. You will spend the same $$ for a bent bracket on eBay that you can get a BNIB OEM one from Z1 for.
Trust me I spent 5 months holding out for a used bracket for a used price. They do not exist. Z1 had the cheapest prices but a good amount for used ones.
I got the Radiator and the core support, if i go ahead and install both of them is it going to make it difficult to install the radiator fan when i get it?
Also, is this the part in question when were taking about the headlight support?
https://www.z1motorsports.com/front-...rt-p-4451.html
New development
So I got the new radiator out of the box and realized something was missing
These lines seem to be soldered into the radiator
My OEM replacement radiator doesn't have these lines
Also on the left side of the current radiator is this
