Sponsored by:
Sponsored by:
Speakers for 350z
Old 02-02-2017, 03:16 PM
alexomar16
alexomar16's Avatar
Default Speakers for 350z
I got an aftermarket radio for my 2006 Z and the stock Bose speakers aren't as loud as I wanted them to be with the new radio. I have a pioneer, and was wondering what are some great quality speakers that are preferred for the Z. Please let me know!
Old 02-02-2017, 03:47 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
This is likely because your stock Bose speakers are rated at a lower impedance than your new HU is set up for. 2-ohm versus 4-ohm I think.
Not sure of the intricacies of the Bose setup since I've never done a "Bose-bypass" or HU upgrade on a Bose based system; but everyone seems to suggest bypassing the Bose amp & sub and starting fresh with all new speakers.
The Audio guys will chime in here NO DOUBT.
S'far as replacement speakers, I'm high on my Focals.
EDIT:
https://my350z.com/forum/audio-and-v...head-unit.html
https://my350z.com/forum/audio-and-v...omponents.html
Old 02-03-2017, 05:16 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
you need to rewire everything to bypass the bose amps... they also run at 2 or 3 ohm, and replace the speakers
been covered a million times or two
Old 02-03-2017, 10:46 AM
JERZ350
JERZ350's Avatar
I bypassed - pioneer HU on the stock sub and speakers. They sound much better than using the stock HU. But they're still crap.
Old 02-05-2017, 12:42 PM
Steelcyclone
Steelcyclone's Avatar
About 6 months ago I picked up a pair of infinity kappa speakers. They sound great and weren't very expensive (little over 100)
Old 02-05-2017, 03:38 PM
chatcher
chatcher's Avatar
I went with Polk. Got them from Crutchfield. The rears came with tweeters and crossovers. Less than $200 for all 6. Very pleased with them.
Old 02-06-2017, 04:52 PM
Spike100
Spike100's Avatar
As Mic has already stated, your stock Bose speakers are not compatible with your new Pioneer HU because Bose uses a different impedance than Pioneer.
You can keep your wiring in place. but you must bypass the Bose amps and replace the Bose speakers. To get the best sound, add a new external amp.
Old 02-06-2017, 08:14 PM
rearranged
rearranged's Avatar
You don't have to bypass the Bose system. Several companies make an adapter/interface that wires in between factory wiring and new head unit. If I remember correctly, it can be had for $30-40.
I got one on amazon for around $32.
MicVelo (02-06-2017)
Old 02-06-2017, 08:21 PM
MicVelo's Avatar
^^^ That there is good, useful info! Figured there had to be a way. I mean, we're merely talking about impedance load and to convert to be suitable is basic electronics.
Old 02-07-2017, 05:57 AM
JERZ350
JERZ350's Avatar
^ Actually you reminded me, that is what I used to hook up my Pioneer HU to my stock BOSE. Forgot all about that. It works great.
Old 02-08-2017, 12:44 AM
The Swede
The Swede's Avatar
There's also some sort of harness modification you can do to remedy the issue. I saw it on the brit forums I think. I'll see if I can find the guide.
Edit:
Found it:
http://www.350z-uk.com/topic/107583-...ume-fix-guide/
Not as simple as wiring in a PAC adapter but supposedly yields better results. Or so they claim.
