Time slip from my first ever GT-R drag - MY350Z.COM Forums
Thread Tools Search this Thread
Old 07-27-2013, 11:51 AM   #1
Mike Anthony
Default Time slip from my first ever GT-R drag
2009 GT-R. EcuTek tune and midpipe.
This was the only run that I got to do. I forgot to switch to my more aggressive tune for the run and ended up running the weaker tune... It could have been a 10.9 which is what I was aiming for...
Mike Anthony is offline   Reply With Quote
Old 07-29-2013, 09:47 AM   #2
bigcloud
Congrats Mike!! Now bring it to VIR!
bigcloud is offline   Reply With Quote
Old 07-29-2013, 11:41 AM   #3
Phenom
Toasty
Phenom's Avatar
Are you on the right or left?
just kidding, nice run. Id love to see the time with the stronger map.
Phenom is offline   Reply With Quote
Old 07-29-2013, 01:01 PM   #4
djamps
djamps's Avatar
Launch control I assume? I ran against (and barely beat) a stock 2011 but it had something awful of a 60-ft like 1.9. My 1.6 put a bus length between us off the line.
djamps is offline   Reply With Quote
Old 07-30-2013, 08:11 AM   #5
Mike Anthony
Yep I used launch control. I can't wait to go back because I know it can do better.
This was at Capitol Raceway. Their rules are super strict and it was so busy I only got one run after 5 hours of waiting. Definitely going to do MIR next.
I've never even looked at VIR, how packed is that one?
Old 07-30-2013, 09:11 AM   #6
quakerroatmeal
quakerroatmeal's Avatar
Good time for the first run. But holy crap 1 run in 5 hours? That's ridiculously.
quakerroatmeal is offline   Reply With Quote
Old 07-30-2013, 01:08 PM   #7
djamps
djamps's Avatar
I usually get a dozen in at capitol as long as I arrive before 6:00PM. After 8:00 or so it gets way crowded. Check out Cecil on weekends or friday nights if you want some good runs.
Old 07-31-2013, 06:43 PM   #8
bigcloud
Mike VIR isn't a drag strip. It's this... I took my IS-F on it and ran very well ( 2:21.096) I also got to ride in a GT-R around the full course as well. You should come out. It's where the big boys play.
Old 08-01-2013, 03:02 AM   #9
Mike Anthony
I would love to do that.... I will need to invest in some better brakes and some better tires than michelin PSS first though. Stock brakes are fine for awhile but they start to crack around the holes after only one track use... They're expensive as f**k so I need to get a dedicated set that won't crack
Old 08-01-2013, 05:06 PM   #10
bigcloud
Mike unless your PSS's are really low in tread they will be good enough for track duty. My PSS's worked just fine at VIR. As for your rotors my 14.1" cross drilled rotors cracked as well. I got one more track day in them then I am changing. Your's should be fine unless they are needing replaced.
Old 08-06-2013, 11:50 AM   #11
Mike Anthony
Quote:
They're about to need to be replaced. After I can get a new set I definitely want to track it.
Thread Thread Starter Forum Replies Last Post
Wheel bearings? Obadabot Maintenance & Repair 12 02-26-2017 06:02 PM
My FI friends, im at a loss of whats causing my issues. i turn to you. Colombo Forced Induction 29 10-10-2015 02:31 PM
Oil change with aftermarket oil cooler XM 1 Engine & Drivetrain 11 10-01-2015 10:44 PM
my tcs and slip light on loudtoyz Engine & Drivetrain 6 09-30-2015 03:48 PM
Tags
wwwevergtcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
