Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > 2003-2009 Nissan 350Z > 350Z Roadster
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-19-2009, 09:09 PM   #1
JuanSilva
Points: 1,404, Level: 21
Points: 1,404, Level: 21 Points: 1,404, Level: 21 Points: 1,404, Level: 21
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default 2004 Roadster 350z. Traction and SLIP lights came on at same time and lost all power.
Both SLIP lights and Traction Control light came on at the sametime. I lost power to my car to where I had no accelaration. and now my Check Engine light is on. Any ideas? I am going to go get it checked but just want to have an idea of what the possibilities could be.
JuanSilva is offline   Reply With Quote
Old 09-19-2009, 09:17 PM   #2
zand02max
zand02max's Avatar
Points: 165,981, Level: 100
Points: 165,981, Level: 100 Points: 165,981, Level: 100 Points: 165,981, Level: 100
Quote:
Mods would help? Bad MAF sensor, CAI? Did you open the hood? Was the top down? Was Pamela Anderson driving by naked?
zand02max is offline   Reply With Quote
Old 09-19-2009, 09:24 PM   #3
JuanSilva
Yah hood was down and everything. I looked it over to see if anything noticeable was out of place but nothing looked abnormal. I just got the car a few months ago no mods that i know of except exhaust and wheels as of now. I just lost all acceleration and I turned the car off and then back on and I could go just fine except the check engine light was on.
Old 09-19-2009, 09:26 PM   #4
zand02max
zand02max's Avatar
open your hood and check your intake box and maf sensor!
Old 09-19-2009, 10:06 PM   #5
Points: 9,433, Level: 65
Points: 9,433, Level: 65 Points: 9,433, Level: 65 Points: 9,433, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
What size tires did you put on the front and rear?
__________________
370Z 2009 Sport Package
davidv is offline   Reply With Quote
Old 09-19-2009, 10:08 PM   #6
JuanSilva
245/20in DC rims
Old 09-19-2009, 10:14 PM   #7
245/20in DC rims
Same size tires all around? Do you have VDC?
__________________
Old 09-19-2009, 10:20 PM   #8
JuanSilva
yah i believe so. its an 04 roadster so i would think it did. what happened was i was driving and I lost all power as i was driving and then both my TCS and SLIP lights came on and stayed on. So i Shut the car off and when I turned it back on everything was drivable and the lights went out but then my check engine came one and is on now. but I could accelerate just fine and everything. Like it had a glitch or something. and yah my tires are the same all around.
Old 09-20-2009, 05:08 PM   #9
zand02max
zand02max's Avatar
Quote:
I know you know this dave but the roadsters don't have VDC other than the GT!
Old 09-20-2009, 08:48 PM   #10
Quote:
I knew it at one time but then I forgot it.
__________________
Old 09-20-2009, 08:53 PM   #11
kajuraelai
Points: 1,556, Level: 22
Points: 1,556, Level: 22 Points: 1,556, Level: 22 Points: 1,556, Level: 22
check battery connection, check make sure you maf sensor isnt loose... check all connections with everything.
kajuraelai is offline   Reply With Quote
Old 09-20-2009, 11:54 PM   #12
Phreakdout
Master
Phreakdout's Avatar
Points: 2,806, Level: 32
Points: 2,806, Level: 32 Points: 2,806, Level: 32 Points: 2,806, Level: 32
Today's Activity: 5.6%
Today's Activity: 5.6% Today's Activity: 5.6% Today's Activity: 5.6%
Your TCS system kicks in when it detects an abnormal speed difference between the rear wheels. (Assuming the tire is slipping.) This is common when you have the wrong diameter tire. (Or you have a really wide tire in back.) It usually happens when you're going around corners. It is designed to cut the throttle to slow the car down and regain traction. There is a switch on the left of the steering wheel. Hit it to disengage the system. You have to do this every time you start the car. No way around it unless you go back to proper sized tires.
__________________
-- The Phreak | '04 350Z Redline Touring Roadster 6spd w/NAV | 350EVO | Eibach | Megan Racing | Ichiba | Motordyne | Cusco | Stillen | Whiteline | SPC | Wicked Tuning | Injen | Greddy EVO2 | Misc CF Engine Parts | Polished Intake and Throttle Body | 20" Giovannas | Nismo V2 | Shine Auto Central 20 Spoiler | Veilside CF Underwings | Seibon CF Hood
Phreakdout is offline   Reply With Quote
Old 09-21-2009, 09:29 AM   #13
JuanSilva
That would cause my Check Engine light to come on and stay on after? It was going around a corner and I did hit the throttle pretty hard going around it. But it cut my throttle drastically to the point I literally had no accelleration at all. Now everything is fine ecept the check engine light is on. Im going to take it in today but I was just inquiring so i can better understand these cars. this is my first Z so I am new to them and how they work. Thanks though, you pretty much hit it right on i think.
Old 10-02-2009, 11:07 AM   #14
na_350z
na_350z's Avatar
Ivan Infante
Points: 4,382, Level: 42
Points: 4,382, Level: 42 Points: 4,382, Level: 42 Points: 4,382, Level: 42
Today's Activity: 1.5%
Today's Activity: 1.5% Today's Activity: 1.5% Today's Activity: 1.5%
Send a message via AIM to na_350z
My SLIP and TCS light turns on too but it's because of my tire sizes. I have 255/35/19 up front and 275/30/19's in the rear. It happens when I go into a hard turn or hard bump but I just drive with the TCS off and like Phreakdout mentioned that solved my prob. As for the Check Engine that's never happened so it might be your MAF but I don't know if that would cause ur Slip and TCS to go off unless it happened all at once type of deal. Let us know what happened?
__________________
2004 Nissan 350ZR: Rays Gram Lights 57s Pro Diamond Black - Vredestein - Tanabe - Berk - JWT - Origin Lab - Megan Racing - Rotora - Sparco 2000 Saleen #137 S-281 Mustang: Borla - Steeda - K&N - UPR - 2003 Ford Lightning: Stock
na_350z is offline   Reply With Quote
Old 10-07-2009, 10:48 AM   #15
JuanSilva
Yah i took it to the mechanic and they scanned it and it ended up being the throttle sensor. I looked it up and the symptoms of a throttle sensor acting up is exactly or close to what i was experiencing (lost of throttle/power, TCS and SLIP light on, and check engine light came on as well. It think it just was a slip and nothing went bad and I am driving just fine now, but I am going to replace the throttle sensor anyways just to be safe.
Old 10-07-2009, 12:05 PM   #16
F34RL355
Points: 1,230, Level: 19
Points: 1,230, Level: 19 Points: 1,230, Level: 19 Points: 1,230, Level: 19
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
similar thing happend to me it was the mass air flow sensor (750$) they wanted luckily warranty covered it all
F34RL355 is offline   Reply With Quote
Old 10-26-2009, 08:06 PM   #17
JuanSilva
Yah i took it to the Mech and explained what the car was doing and they checked the code and checked the throttle sensor and everything was fine. They said it was just a glitch in my CPU because sense they reset the code and light it hasnt acted up. The only thing now is my side airbags keep malfunctioning. When i took it in to have the Engine light reset it was reset as well, and they told me it was my side airbags and it came right back on the same day i took it from the shop.
Old 10-27-2009, 06:38 PM   #18
Blooster
Blooster's Avatar
Points: 2,241, Level: 28
Points: 2,241, Level: 28 Points: 2,241, Level: 28 Points: 2,241, Level: 28
Today's Activity: 3.2%
Today's Activity: 3.2% Today's Activity: 3.2% Today's Activity: 3.2%
Funny you should mention that - my driver's seat side airbag is now being replaced by Nissan for the 4th time.
__________________
SFZCC rokZ meet info here
Blooster is offline   Reply With Quote
Old 10-31-2009, 04:33 AM   #19
JuanSilva
seriously. wtf? what was the time period in between replacements? did they keep charging you everytime?
My350Z
350 Z
Paid Advertisement
Tags
2004, 350z, 350zx, check, codes, engine, light, lost, nissan, off, power, resetting, ses, slip, tcs, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
