Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > 2003-2009 Nissan 350Z > 350Z Roadster
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 09-23-2009, 06:46 AM   #1
allycat
Points: 878, Level: 15
Points: 878, Level: 15 Points: 878, Level: 15 Points: 878, Level: 15
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Has anyone replaced or took off the protective tape
Has anyone replaced or just removed the protectoive tape on the tonneau cover. Just got a used roadster and thier is dirt under the tape that I can't clean. The part I am referring to is number 2 on the picture.
allycat is offline   Reply With Quote
Old 09-23-2009, 08:46 AM   #2
cheshirecat79
cheshirecat79's Avatar
cheshirecat79
Points: 5,147, Level: 45
Points: 5,147, Level: 45 Points: 5,147, Level: 45 Points: 5,147, Level: 45
Today's Activity: 35.6%
Today's Activity: 35.6% Today's Activity: 35.6% Today's Activity: 35.6%
Send a message via AIM to cheshirecat79 Send a message via Yahoo to cheshirecat79
don't do it, the cover will come off at very high speeds (45+ mph)
this is a well documented issue
cheshirecat79 is offline   Reply With Quote
Old 09-23-2009, 09:21 AM   #3
allycat
What cover will come off ?? So that means you can never replace the tape if it gets all messed up or ig you have to repaint that area ?
Old 09-23-2009, 09:23 AM   #4
cheshirecat79
cheshirecat79
Number 1 in your diagram.
... which I really like, btw
Did you draw that?
If so, you should be a professional draftsman/woman.
Old 09-23-2009, 09:33 AM   #5
allycat
No I didn't draw it I got from a Nissan parts site that sells all those parts, so you are telling me the Tonneau cover will come off if you remove that protective tape, don't see how that's possible all the tape does is protect the paint. We are talking about the same thing here, I am talking about the clear tape on top of the cover were the rubber from the top sits, it's like the 3m clear bra film
Did you draw that?
Old 09-23-2009, 01:02 PM   #6
SHILOW
Points: 1,184, Level: 18
Points: 1,184, Level: 18 Points: 1,184, Level: 18 Points: 1,184, Level: 18
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
I took that tape off because it had grime under the edges. I'm not sure if there are any issues caused by doing this. If your going to remove it be very carefull...go slowly because it can take some paint with it. I'm not sure but I think it is there to protect the paint. It also maybe there to help the seal of the top.
SHILOW is offline   Reply With Quote
Old 09-24-2009, 06:21 AM   #7
allycat
Thanks Shilow that's why I want to mine off because of all the grime under the edges. I was told by Nissan that is only to protect the paint and nothing more. I started taking some of it off last night and your are right it peeled a little paint. So I stopped and going to get some goop-off and see if that makes it come off easier.
Old 09-24-2009, 07:01 AM   #8
SHILOW
Just take your time. It is a practice of patience. I had to pull a few inches and step away. I would suggest pulling the tape slowly and leaving some of the adhesive behind. Then go back with the goo gone and/or rubing compoud to clean it off the paint.
Old 09-24-2009, 07:34 AM   #9
Darkpath
Darkpath's Avatar
Points: 1,399, Level: 20
Points: 1,399, Level: 20 Points: 1,399, Level: 20 Points: 1,399, Level: 20
a blow dryer might help with the process as well... In fact I think I would use both. First a little Goo-gone and and then a little heat to break the adhesive bond before I ever began peeling..
Darkpath is offline   Reply With Quote
Unread 02-11-2012, 11:49 AM   #10
Michael0974
Points: 425, Level: 8
Points: 425, Level: 8 Points: 425, Level: 8 Points: 425, Level: 8
Today's Activity: 1.8%
Today's Activity: 1.8% Today's Activity: 1.8% Today's Activity: 1.8%
For any of you guys who have removed the plastic strip, have you found that the paint is coming off over time due to the top rubbing against the cover? My strip is all yellow and nasty.
Michael0974 is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
3m, brakes, protective, tape, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
