gah! another top wont close thread, please help
on
Hey guys, bought a new-to-me 04 350z rag top. I have had it for 2 months and am having issues w the top. When I purchased it, obviously top worked but as it usually does, a month into it, it started being sluggish. At this point I got the top to mostly go through the close process, the back lid closes and at that moment the rest of the process stopped. I can not close it or reopen it from this point. Below are the pic. The last step doesn't fo and it seems stuck. I can hear the clicking of what I think are relay switches bit nothing else happens. Please help w diagnosis as i dont really want to.drop 1-2k foe dealer to tell me I have to replace the whole roof. thanks!
on
or here is a diy on how to fix it hope it helps
https://my350z.com/forum/maintenance...th-photos.html
on
it opens lets say 2 inches every single time the door is opened until its completely opened all the way down. What that means is i cannot go through car washes since people dont pay attention to something like that.
Any clue what it could be? (it doesnt fall down, it actually opens as if its meant to do that lol)
yes sir, that did it . I have never taken a motor apart before but now that i looked at it, it makes sense that it would go "bad" since you are using the brushes up. Thank you , now if i can figure out why my drivers window opens a bit every time i open the door...
Yes the window opens a little when you open the door and visa versa when you close it. This is to create a tight fit with the window seal, better water proof. Also if the window didn't do that then the glass would have streak marks etched onto the top portion of the glass well. It only goes down a couple of millimeters though. Couple of inches is a lot.
I don't think it is to create a better seal, I think the window goes down to protect it from shattering when you close the door since there is no door frame around the window. The coupes do the same thing so it isn't just a roadster seal thing.
As to why your window goes down 2 inches and doesn't go back up, I would think the regulator is probably going bad and the window is slipping.
on
08-06-2021 06:19 AM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
