quicker accelation? faster?
09-04-2014, 02:25 PM
Senior Super Moderator MY350Z.COM
Quote:
Originally Posted by
dannyt40
I just find out on my 2005 350z that there is a governor on the bottom my gas pedal. You can look underneath and you will see a medal bar, this restricts your car from accelerating quicker. 1.) take off the whole gas pedal with a few screws. 2.remove the governor by using a metal hand saw tp cut it off, and When removing it, be careful to put it back exactly how you took it off. Here you are folks. now you can pedal to the metal aaallll the wayyy.
09-04-2014, 03:03 PM
SmoothZ
No really. It works. I shaved .4 seconds off my 0-60 times. I swear and I went to Rutgurz so you can trust my words.
09-04-2014, 03:39 PM
General & Tech Moderator MY350Z.COM
350zHalleck
Calling bs on that...makes no scents. I mean cents. I hate it when when folk don't make since.
09-04-2014, 04:04 PM
PayPal gift me 10k to my GF account in Dirty Jersey and I will send you a K1 Attack kit and a copy of my Rutgurz diploma.
09-04-2014, 04:18 PM
on
I heard there was this chip for only $20 that can increase power up to 30hp. That has gotta be cheaper than buying a medal saw.
09-04-2014, 04:32 PM
POS VETT
Sssshhh. That's a secret mod
09-04-2014, 05:17 PM
Lead Super Moderator MY350Z.COM
09-04-2014, 06:40 PM
How much for the metal hand saw shipped to Canada?
09-04-2014, 07:09 PM
Have you guyz tried cutting the throttle cable to raise the redline?
09-04-2014, 07:30 PM
No, but I took an eraser to the tach and now I can rev past 9k.
09-04-2014, 07:50 PM
[QUOTE=mr. sparco;10458908]Have you guyz tried cutting the throttle cable to raise the redline?
Way too much trouble. All you have to do is add 25 cm from the pedal to the throttle cable, loop it a couple of times. Braided picture-hanging wire is spot on diameter.
09-05-2014, 03:11 AM
+1
Maybe he had a Toyota floor mat stuck under there that is gone now. No way the pedal caused that, I mean petal. Or is it peddle?
I mean wurd.
09-05-2014, 04:22 AM
Emski
Please type up a DIY with pictures for this mod. I have been researching and all I need is a bit more info before I try doing this. Thanks for the help.
09-05-2014, 06:10 AM
using a sharpie, write "9" on a piece of duct tape. stick it over the "7" on your tach. boom. you're redlining to 9K.
09-05-2014, 06:57 AM
Syner
OH snap how did I not think of that. I'll bet it picks up 8-9whp on the dyno after the tach mod.
09-05-2014, 07:12 AM
350zHalleck
09-05-2014, 03:03 PM
on
*sense
09-05-2014, 03:10 PM
09-05-2014, 03:15 PM
Thai-Lights
*sense
Oh no it is definitely since. Or is it cents?
09-05-2014, 03:19 PM
If I cross out the oil pressure gauge and write in boost, does that mean I haz turbo?
