Project: Nismo roadster - Page 6 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 02-12-2015, 10:53 AM   #101
DeusExMaxima
Quote:
Originally Posted by Bama J View Post
Nissan 'been working on a Nismo Roadster too....
http://www.msn.com/en-us/autos/chica...ago/ar-AA9jnlG
Nice looking car. Its something that they should have done years prior I think.
DeusExMaxima is offline   Reply With Quote
Old 02-12-2015, 12:59 PM   #102
Bama J
Bama J's Avatar
^^I completely agree. Been following this thread for a while. Car looks great. Nice work in creating something they should have built from the factory.
Bama J is offline   Reply With Quote
Old 02-12-2015, 04:35 PM   #103
DeusExMaxima
Thank you....today I painted and cleared one of the side skirt extensions. Since the side skirt extensions are not particularly big, I had the paint store put the paint in spray cans with one can per side of base and one can of clear per side. It was the perfect amount of paint, and weather was paintin' weather!
The paint store ran out of KH3 but ill have the other can of base tomorrow. I may get the fasteners from the stealership since some are cheap.
Anyway here is a pic of the paint skirt extension:
Old 02-13-2015, 12:11 PM   #104
Resmarted
I've always been curious what my smoothline top would look like with a rear spoiler. I do think it would help that rear spoiler out, as it extends past the brake light.
But I say you ditch the rear spoiler m8.
Resmarted is offline   Reply With Quote
Old 02-13-2015, 12:19 PM   #105
Resmarted
Also for rear shocks, don't bother getting adjustable. Pain to adjust on the roadster unless you drop them each time.
You should get stock dampers and get some nismo (from the actual road car) springs. People sell them from time to time. Under 400 bucks should get you them. No drop, so you won't have to deal with re cambering the wheels to stay in spec.
Old 02-13-2015, 12:25 PM   #106
DeusExMaxima
Resmart....Ill trade you my spoiler for the hardtop
I thought about some Tein springs as the drop is .5". How about Tokico HPs instead of the adjustables? Any suggestion for anti-sway bars?
Old 02-13-2015, 12:34 PM   #107
Resmarted
Hotchkis sways. Adjustable sways are key. But what sway settings you use are all up to what springs/dampers and rubber you run and how you want the car to handle. More and more of that is up to you/how you want the car to perform.
A good example; understeer is generally less desirable, but it is much more street friendly/safe. Actually helps stability, without running stupid toe settings. But can make the car "slow to respond" and not very fast around tight sections.
I need a stiff rear sway and springs but I have 245's in the front and a 305 in the back on basically a street r compound lol.
I think the S-techs are a great spring for the street as they're progressive in the front which will help low speed ride "smoothness" but still have decent rates. I think you'd be happy with them, just keep in mind though you will have more camber in the front... Which makes the car turn in a bit faster and "adds over steer" but also makes the car dart a bit more and wears through tires faster. I doubt it would be a huge difference but it does still happen.
Old 02-13-2015, 02:51 PM   #108
DeusExMaxima
Im looking for something street friendly but perhaps some track days and spirited street driving. I am a long time autocross racer and did road races and time trials. I was thinking Hotchkiss for the sways, Tein H tech springs and Tokico HP shocks. The springs only drop it .5 inch in front and .28 inch in rear.
Old 02-13-2015, 04:46 PM   #109
DeusExMaxima
I painted and cleared the other side skirt extension today. Im looking to mount them this weekend.
Old 02-13-2015, 06:37 PM   #110
Z1NONLY
Z1NONLY's Avatar
My Konis adjust from the fender area. I can't imagine that a roadster would make it more difficult. (I do have to jack up the car a bit so the tire droops down and I can get my hand to the adjustment, but I don't have to remove any parts.)
Z1NONLY is offline   Reply With Quote
Old 02-13-2015, 09:18 PM   #111
Resmarted
Quote:
Well the ones that adjust on the bottom aren't an issue, but I thought a lot of coils adjust at the top? I know HKS doesn't... anyway.
Sounds like a good setup. What tire sizes you going to run?
My car has all the weight out of whack with the **** going on in it. I moved a big old battery to the rear and removed the front harmonic damper weight.... And now A/C, and the top etc. I'm going to have to corner weight it before I pick the spring/toe/camber setup, because at this point I have nearly no clue what it weighs.
Old 02-14-2015, 12:53 AM   #112
DeusExMaxima
I like the stock size tires but that may change. At some point ill probably go to 245 front and 265 rear.
Old 02-14-2015, 11:24 PM   #113
DeusExMaxima
I spent all day mounting one side skirt. Heres what happened...I called the stealership to inquire if they had the correct mounting hardware. Most of it had to be special ordered and would take about a week to get here and would cost about 70 or 80 dollars. I didn't want to wait or pay 70 or 80 dollars for some nuts and bolts. I decided to try to figure out the special bolts that mount the side skirt extensions to the original side skirt. I discovered that there are body panel bolts that would fit the bill. Body panel bolts use a 10 millimeter head on a 6 millimeter shaft with 1.0 thread pitch. It has a large washer that is slightly below the head. I determined that if I grind down the head enough it will slide in the mounting point of the side skirt extension. as I tighten the bolt so large washer will tighten against the head and stop it from turning allowing me to tighten the bolt even more.
This process took a lot of time. it was also difficult figuring out where to drill the holes in the original side skirt in order for the bolts to go through them and lock to the side skirt. I figured it out and I am extremely pleased with the end result.I got one side done and I will do the other side tomorrow. Anybody want pictures?
Old 02-15-2015, 07:55 AM   #114
che69velle
che69velle's Avatar
che69velle is offline   Reply With Quote
Old 02-15-2015, 09:01 AM   #115
DeusExMaxima
Presenting....a 350z convertible with an oem nismo body kit:
Old 02-15-2015, 09:06 AM   #116
DeusExMaxima
More...
Old 02-15-2015, 09:11 AM   #117
che69velle
che69velle's Avatar
Now for some nismo badges
Old 02-15-2015, 12:33 PM   #118
DeusExMaxima
Old 02-15-2015, 02:57 PM   #119
che69velle
che69velle's Avatar
Lol I just realized that your license plate looks like it says "hero"
Old 02-15-2015, 06:13 PM   #120
DeusExMaxima
I was thinking of this license plate for it:
Thread Thread Starter Forum Replies Last Post
FS: 2003 Touring Edition 350z-6MT-2Tone-40K Miles - $14k - NJ ars88 Zs & Gs For Sale 18 04-04-2016 07:52 AM
FS: NISMO S-Tune Catback Exhaust nanotech Exhaust 6 10-02-2015 05:02 AM
Hi! Ganglio Europe 1 09-26-2015 07:06 PM
Touchscreen in a Roadster jlb Audio & Video 3 09-15-2015 06:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
