Same size tires and rims on the four corners
Old 11-16-2015, 04:30 PM
neilca
neilca's Avatar
Default Same size tires and rims on the four corners
I just bought a 2008 Grand Touring Roadster with the Brembo brakes. The wheels are scuffed up from scrubbing curbs and I was looking to replace them. My thought was to go to the same size front and rear so I can rotate tires. Has anyone done this? What size did you settle on? I am not looking at increasing the 18" diameter.
Old 11-16-2015, 04:32 PM
turboed350z
turboed350z's Avatar
Nope. Out of the tens of thousands who are on this forum, no one has ever done this before...
Old 11-16-2015, 04:51 PM
PP08HR
PP08HR's Avatar
Don't mind that other guy he's not very nice. Probably some ego issues.
But anyways, yeah you can run a "squared" set up.
Run a search of this site through google and you'll get some good threads with tire and rim sizes that'll help you out.
New ride huh? Lets see some pics!
Old 11-16-2015, 04:58 PM
neilca
neilca's Avatar
Thanks PP08HR,
I had searched but did not have the word "Squared", makes sense, just never heard it before. My car is black and it has been raining here for some time. It is in dire need of a bath before I can get pics.
Old 11-16-2015, 05:22 PM
turboed350z
If only there was a section where it was label "wheels and tires" where people go to discus this question. If only there was a sticky that had all this information covered already....
The following 3 users liked this post by turboed350z:
Cux350z (11-16-2015), HRMoneyPit (11-16-2015), terrasmak (11-16-2015)
Old 11-16-2015, 05:38 PM
HRMoneyPit
HRMoneyPit's Avatar
^^^^^ beat me to it
Old 11-16-2015, 05:41 PM
PP08HR
PP08HR's Avatar
Yeah or we could politely lead him in that direction...
Or just be a bunch of Z tard d bags.
Great job guys!
SteveB_Kingston (04-10-2016)
Old 11-16-2015, 06:02 PM
turboed350z
Must be a "participation trophy" generation
Old 11-16-2015, 06:08 PM
verdict.
verdict.'s Avatar
Yes, many people run a squared setup. Take a look in the Wheels/Tires section.
Old 11-28-2015, 07:16 PM
chitownpete
chitownpete's Avatar
Neilca congrats on your new car! Ignore the smartasses, there's quite a few on this site. That being said a search will give you the details to your questions. Enjoy that Car.
Old 11-28-2015, 07:40 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Yeah a search will let you know not to do that because your going to have problems with your traction control...
Originally Posted by dboyzalter
Default Also.. Q: What size tires should I buy?
Q: The "Slip" light come on randomly, especially in turns, even though my tires aren't slipping. What's up with that?
A: Both the Traction Control System (TCS) and Vehicle Dynamic Control (VDC) can cause the "slip" light to come on. There are a couple of things that can make it come on even though you don't feel/hear your tires slipping.
The most common cause for this behavior is replacement of the OEM tires with a different size. All Zs come with staggered tires, that is to say the fronts are a little shorter than the rears. This causes the tires to rotate at different rates which TCS and VDC depends on for normal operation. If you install tire combinations that don't maintain that stagger, it can cause problems for TCS/VDC resulting in the "slip" light illuminating.
The stock tire sizes and Outside Diameters are:
225/50/17 25.9"
235/50/17 26.3" (0.4" stagger)
225/45/18 25.9"
245/45/18 26.7" (0.8" stagger)
245/40/18 25.7"
265/35/19 26.3" (0.6" stagger)
265/40/18 26.3"
285/35/19 26.9" (0.6" stagger)
When choosing new tires, try to find front/rear pairs that maintain the stagger of at least ˝" and less than 1". You should also look for front/rear setups that maintain the same OD as that will keep your speedometer and odometer accurate.
Here are the most common "upsized" tire combinations. These are known to work and keep TCS/VDC happy.
245/40/18 25.7"
275/40/18 26.6" (0.9" stagger)
245/35/19 25.8"
275/35/19 26.6" (0.8" stagger)
255/35/19 26"
285/35/19 26.9" (0.9" stagger)
245/30/20 25.8"
275/30/20 26.5" (0.7" stagger)
Check the manufacturer's website to find the Outside Diameter of tires before you buy them, or use one of the online tire calculators:
http://www.miata.net/garage/tirecalc.html
http://www.wheelsmaster.com/rt_specs.jsp
A less common cause for the "slip" light to illuminate comes from replacing the fronts or rears only. If you replace only the fronts or rears, the stagger may not be what you think it is because the other worn pair is actually up to ˝" smaller than they were when new.
New tires also come with a release agent on the surface of the rubber that must be worn off. That makes them slick and can result in your tires actually slipping, hence the "slip" light.
NOTE: The slip light does and will come on during "normal" driving that is unrelated to tire size or wear. If you apply too much throttle when launching or going around a turn, the wheels will slip and cause the light to illuminate. Also, driving on slick road surfaces (water, oil, rocks) can also cause your tires to slip.
__________________
2004.5 Daytona Blue Track ... Gone
New to MY350Z? Have a question? Please read this thread first: Top 100 Questions Thread (CLICK)
Old 11-30-2015, 03:43 AM
VenomGT9
VenomGT9's Avatar
Squared is for squares
Old 03-19-2016, 07:24 PM
wallygator
wallygator's Avatar
I have a 2004 roadster with 245`s all around on anniversary's rims
Old 03-27-2016, 07:02 AM
neilca
neilca's Avatar
I bought the same size rims but chickened out on changing the tire size. I am going to see how these wear without rotation.
Wallygator,
I assume you had no issue with the traction control by going to 245's. Thanks for the input. I may do this if I do not like the tire wear.
Old 03-27-2016, 11:13 AM
dboyzalter
dboyzalter's Avatar
You could do 245/40 front 245/45 rears... Some people claim that they run a square same size tire front and rear but its not really recommended unless you have a base model z.
Old 03-27-2016, 11:46 AM
HRMoneyPit
HRMoneyPit's Avatar
Bull ****
I don't have a base model and I run 285s with 0 problems
Old 03-27-2016, 01:11 PM
dboyzalter
dboyzalter's Avatar
Originally Posted by HRMoneyPit
Bull ****
good for you Its not like im making this up, its just not a recommended thing to do...
sccarally
Meet-Ups / Events (Texas)
11-24-2015 04:34 PM
EnjukuRacing
Brakes
11-16-2015 06:23 AM
NeoGixxer
Wheels Tires
11-15-2015 09:13 PM
03s2kman
11-12-2015 09:59 AM
Quick Reply: Same size tires and rims on the four corners
