Convertible Top Shifting
Hey guys,
So I am having a problem with my top shifting back and forth when i am closing it. I was wondering if anyone could tell me if the top needs to be programmed to close in the correct location or is it just a nut or bolt that needs to be tighten. When i close the top the lock hooks on the passenger side does not fall into place so i have to push the top back slightly to be able to lock it down.
Thanks,
Thanks,
General & Tech Moderator
You can pull the plastic cover underneath the 1st bow. There you will find the linkage and adjusters for the front clamps. Unless your frame is bent. gl
