370Z Brakes & Suspension 370Z stoppers, coils, shocks/dampers
Adjusting adjustable end links
Old 07-01-2015, 08:18 PM
CptWiggles
CptWiggles's Avatar
Default Adjusting adjustable end links
1) With the car at rest disconnect one end of one end link on each axle. This will remove any torsional load on the sway bar.
2) Loosen the jam nuts and adjust the end link until it can be re-connected without moving the sway bar from its resting position.
I understand all of the above, but I can't find what the "resting" position is. The sway bar itself swivels about 90 degrees when not connected to any end links, so what is the correct position or angle to place the sway bar?
Old 07-02-2015, 02:08 AM
superlim9
superlim9's Avatar
in my opinion and experience, the resting position of the bar ends should be horizontal and the endlinks should be perpendicular as close to 90 degrees as possible
08-06-2021 06:19 AM
apex locator
07-23-2021 02:27 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
pr_350z
10-01-2015 05:03 PM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: Adjusting adjustable end links
