Front Brake Sqeaking 08 GT
on
I own a 08 Grand Touring with brembo brakes and my front left speaks/squeals as i am braking lightly. Went to a shop to get it checked and was told that my brakes have are at 50% or more life left, but they still continue to squeak as i brake. Any suggestion on what i could do to fix the problem would help a lot. Thank you!
350Z/370Z Tech Moderator
Plus, while pads are out, check fore/aft chamfer of pads. If none, re-cut 45 deg chamfer, run some 220 grit sand paper across the faces of both pads and rotors to knock down any glaze, reassemble.
Administrator
OP, did you remedy your problem?
Twenty4
04-15-2016 04:50 PM
