Differential *Cross Compatibility*
on
the rear camber arms and toe arms are the same I believe .... I believe this because when I ordered my ichiba camber arms for my 370 , they said 350z on the box, and were installed with no problems..
the diff is one I would like to know too
Former Sponsor
on
camber and toe arms are NOT the same. Some companies may claim they are. Fitting and working the way they should are not the same thing
differentials are swappable (MT differentials for a Z33 swap into a Z34 and vice versa, and same for AT)
ring and pinions are different, but swappable, again MT for MT, AT for AT
on
I'm the Parts Manager at Stadium Nissan.
I traded my '08 Roadster in on 40th Anni 370z.
I removed the Diff and Shortshifter from my 350z to install in my 370z.
The Differential is Identical except for the final drive ratio. The stock ratio on a 370z is 3.69, 350z is 3.59.
My diff housing was out of a G35 that I installed 4.08, Nismo Diff and a Nismo diff cover onto. It bolted straight in and let me tell you it is INSANE in the 370z, absolutely fantastic!!!
xirtam
10-03-2015 02:06 PM
08, 350z, 370z, 44, compatiable, compatibility, compatible, diff, differential, differentials, drive, final, suspension, swap, swaps
