oil catch can--will this work
This catch can has a tube that will lead the oil to the bottom of the can and internal baffling (there are actually 2 internal chambers) to keep the oil there. Extremely efficient design that keeps the oil in the can without using the steel wool mesh that has been know to let loose steel pieces that can end up in your engine and damage it. This is as good as it gets in modern catch can design!
Catch the oil and moisture that are caused by engine blow by gasses that cause sludge and carbon buildup inside the engines intake tract, heads, and valves especially on turbocharged cars and trucks. The oil catch can will keep your engine clean and at peak performance for years to come!
http://www.ebay.com/itm/VMS-ALUMINUM...item43b5a80900
albino bob is correct about not using the filter. I don't view it as leaking vacuum rather allowing unmetered air into the IM. I've had their original design catch can (no breather filter) for a while and even without the drop tube it works perfectly fine. If you do decide to go with this one you can go ahead and throw their tubing directly into the trash can and buy a heavy heater hose to use instead. Between radiant engine heat and hot gases traveling through it you need tubing that won't collapse under vacuum.
11-09-2020 10:27 AM
