370Z Exterior & Interior 370Z body kits, exterior modification, interior styling and lighting
Looking for Power in Center Console
Old 04-03-2012, 02:43 PM
gy954
gy954's Avatar
Default Looking for Power in Center Console
I thought it would be easy to locate a 12VDC source once I pulled the cup-holder/switch piece out. Not so. Can anyone help. And by the way, what are the two unused connectors in there?
Old 04-03-2012, 03:11 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
Do you have a 12v socket behind the armrest? My 03 does. Perfect 12v source.
Old 04-03-2012, 03:50 PM
bmccann101
bmccann101's Avatar
and there ya go. otherwise the radio is right there to tap off of and run a short line.
You dont even want to see how much wiring i have running thru mine. :>)
Old 04-05-2012, 03:28 PM
gy954
gy954's Avatar
Default Thanks All
I bit the bullet and removed the center console today, so that I could tap into the console power-outlet supply line. Not as hard as I'd feared; not as easy as I'd hoped. The results are that I now have powered switches which will feed additional goodies (e.g., DRLs).
Attached Thumbnails Looking for Power in Center Console-console_18_nightlights.jpg
04-22-2021 09:42 PM
Quick Reply: Looking for Power in Center Console
