370Z Maintenance & Repair 370Z upkeep and diagnosing/fixing problems
Tire Pressure Warning Light
Old 12-03-2010, 11:25 AM
shakalaka
shakalaka's Avatar
Default Tire Pressure Warning Light
So today I finally took the Z out after a while as the roads were pretty bad cause of the snow. It finally cleared out and most of the roads were fine so I thought why not. Just outside the house in the inner roads there is some ice which makes the ride really bumpy. So pretty much as soon as I took the car out the tire pressure warning light came on.
So I said no worries, it has done that before. It has come on previously when I'd go over some bumps or something and then after turning the car off and on it would go away. But this time when it came on the car also beeped for about 10 seconds. A long stretched beep which I have never heard before. So I read the manual and it says the sign will come on when the tire pressure is low and the chime will sound if one of the tires is flat.
I looked around and all the tires seem fine. None of them seem flat, I am pretty sure if one of them was flat it would be pretty obvious. But the light isn't going off after I turn the off and on again and it beeps still. I am going to check the tire pressure in a bit with a tire gauge but I am pretty sure it should be fine. Also in the manual in one spot it says 'tire pressure shown in the display may rise or fall while driving depending on the driving conditions (heat, etc) and/or the outside temperature. This does not indicate a system malfunction.'
So obviously it's fairly cold out right now. About -10 Celsius. My question if that sign and the chime could be happening because of the mixture of bumps on the road and outside temperature? How can I make the light go away from the display and get it stop beeping every time I start the car.
Old 12-03-2010, 12:25 PM
gixxerthekid
gixxerthekid's Avatar
Let the beatings begin....
Old 12-03-2010, 12:44 PM
shakalaka
shakalaka's Avatar
Let me be the first...
Old 12-03-2010, 12:48 PM
KornerCarver
KornerCarver's Avatar
The colder the temperature, the lower the pressure in your tires. Check the tires and I'll bet one of them is low. Add some air and your problem should go away.
Old 12-03-2010, 01:42 PM
Not sure how the 370Z TPMS works. Never had a problem.
Old 12-03-2010, 01:47 PM
laser24
laser24's Avatar
unless the battery in the sensor is dead..1 of them in my 09 maxima is dead and the light stays on,, ill fix it when i goto change tires..
Old 12-03-2010, 03:48 PM
R350Zz33
R350Zz33's Avatar
wow you sir are a dedede. Blow up a basket ball and put it out in the cold it deflates put it in the sun and it inflates same concept with tires.
Old 12-05-2010, 09:08 PM
shakalaka
shakalaka's Avatar
Does anyone know below what psi does the tire pressure warning light come on?
Old 12-14-2010, 02:23 PM
hugo350z
hugo350z's Avatar
mine comes on if its below 20psi
Uriyo_
09-08-2021 08:46 AM
apex locator
07-23-2021 02:27 AM
350z82
10-01-2015 06:25 PM
Quick Reply: Tire Pressure Warning Light
