Wiring Color code Guide for 350Z
Old 08-02-2007, 07:19 PM
sumfknguy
sumfknguy's Avatar
ok.. so i took on the daunting task of running new speaker wires through the SMJ harness in the doors... damnit
My doors will not lock electronically anymore.. everything else (windows, hatch lock, blah blah) works.. with these 2 wires listed above:
Power Lock red - driver door module in door
Power Unlock lt. blue (double pulse) - driver door module in door
can i troubleshoot the issues? Like as in a voltmeter to see if they are getting juice while hitting the switch? And do the colors for the wires stay the same as they come out the SMJ harness into the door?
Old 11-08-2007, 04:06 PM
cbr900son
cbr900son's Avatar
Originally Posted by CaliBoy
BLEH NO 2006!
Old 12-03-2007, 08:20 PM
Vaughan
Vaughan's Avatar
I'd like to thank you in advance for doing some backwork on this. I followed wires all around a friends car while working on his audio ( no service manual ) and it was quite a pain.
Thanks again.
Old 12-27-2007, 06:36 PM
driftk1d
driftk1d's Avatar
Originally Posted by 16psibrick
audio:
Radio 12v
yellow
radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
all wiring guide courtesy of DEI
what numbers do each of these represent in daces picture he posted?
i need to know so i can plug them back up
Old 02-07-2008, 11:13 AM
Roper215
Roper215's Avatar
Default Wire Colors
What are the colors from the headunit for the Front Speakers and Subwoofer?
Coming out of the headunit are there eight (8) total wires for the fronts (Left/Right Woofer/Tweet +/-) or is it only four (4) (Left/Right +/-) and what are the aforementioned colors that represent these wires?
Where does the "EQ" take place in a 08 Bose system, within the headunit or within the amplifier?
Thanks, I'll be putting on my flame suit...
Old 03-05-2008, 06:15 PM
grumpysmurf
grumpysmurf's Avatar
Grab the 07 manual from http://www.aubreyandcharles.com/NissanServiceManuals/
then open pg.pgf
Old 03-13-2008, 05:23 PM
Roper215
Roper215's Avatar
Default Stereo Done / Follow Up
then open pg.pgf
Cool, Thanks...
After getting into the hatch area, I was able to make sense of what I was reading...
My install went well, the splicing was a pain...
I wasn't able to get the sub signal to work as planned, so I just tapped into the signal from the fronts fed it through a crossover and sent it to my subs.
Anyone that says JL is just a name has never used their Cleansweep product, worked amazingly well, I am very impressed by how easy it was to install, and how well it "cleaned" up the stock signal.
I understand what people mean about the bass response from the stock location... i have the box firing upwards in the stock sub location... there just is not enough room for the sound to propagate correctly... I am not sure what I will do to fix this problem...
Any advice would be welcomed in this department...
Focals are definately worth the hype, but I will probably upgrade to Seas at some point in the future... older ears do not do so well with tweeters that can shatter glass.
Thanks for the help
Old 03-30-2008, 03:06 PM
JonnyC
JonnyC's Avatar
FYI for anyone looking to splice into the Parking light circuit w/o having to go to the fuse block in the engine bay...
Btw, this was on an '03 Z
Driver's kick panel, above the fuse block
Red w/ Blue stripe
Had to cut some of the zip ties holding the loom because it was very hard to bend (noted in yellow, one further up as well). It's also pretty hard to get a screwdriver up there to pop the clip loose. The red circle is where the white/blue ignition (ie. switched) wire is as well.
Hopefully this helps someone out, since there isn't much info on it, and there are multiple red/blue wires in the driver's kick panel.
linbabyfirstZ (04-13-2023)
Old 04-01-2008, 06:41 AM
MI 35th
OGPremierMafia
MI 35th's Avatar
Subbed for the future wiring info. Thanks Guys.
Old 04-09-2008, 02:17 PM
Crom
Crom's Avatar
Nice info....
Old 05-06-2008, 06:20 PM
Al Kapwned
Al Kapwned's Avatar
Default 2006-2008 Wiring
Here is the DEI wiring for 2006-2008 models
Item - Wire Color - (Polarity) - Wire Location
12 Volts - Green (40A) - (+) - Ignition Harness
Starter - White/Red - (+) - Ignition Harness
2nd Starter - White/Green - (+) - Ignition Harness
Ignition - Black/Red - (+) - Ignition Harness
Accessory - White/Black - (+) - Ignition Harness
Keysense - Black/Red - (+) - Ignition Harness or BCM in driver kick, pin 37
Data Bus - Yellow - (Data) - Driver kick or BCM in driver kick, pin 22
Can Bus High - Blue - (Data) - Data link connector under driver dash, pin 6
Can Bus Low - Pink - (Data) - Data link connector under driver dash, pin 14
Power Lock - Black/Red - (-) - Driver door module in door, pin 6
Power Unlock - Lt. Blue (Double Pulse) - (-) - Driver door module in door, pin 7
Lock Motor - Purple - (5 Wire) - BCM in driver kick, pin 50
Driver Unlock Motor - Yellow - (5 Wire) - BCM in driver kick, pin 44
Passenger Unlock Motor - White/Red - (5 Wire) - BCM in driver kick, pin 51
Parking Lights (+) - Red/Blue - (+) - Driver Kick, harness to rear
Hazards - Green/Red - (-) - Switch or BCM in driver kick, pin 29
Turn Signal (Left) - Green/White - (+) - BCM in driver kick, pin 45
Turn Signal (Right) - Purple/White - (+) - BCM in driver kick, pin 46
Headlight - Red/White (L), Red (R) - (+) - Lights or IPDM E/R, gray 16 pin plug
Reverse Light - Orange or Lt. Green - (+) - Driver Kick, Harness to rear
Left Front Door Trigger - Blue - (-) - BCM in driver kick, pin 62
Right Front Door Trigger - Pink - (-) - BCM in driver kick, pin 12
Dome Supervision - Pink - (-) - BCM in driver kick, pin 48
Trunk/Hatch Pin - Red/White - (-) - BCM in driver kick, pin 58 (Coupe) or 57 (Conv)
Hood Pin - Lt. Green/Black - (-) - Hood pin switch under hood
Trunk/Hatch Release - Pink - (-) - BCM in driver kick, pin 30
Trunk Release Motor - Blue/Red - (+) - BCM in driver kick, pin 68
Fuel Door Release - Blue/Red - (-) - Release switch on dash
Factory Alarm Arm - Arms With Lock
Pactory Alarm Disarm - Disarms with Unlock
Disarm No Unlock - Single Pulse on power unlock wire
Tachometer - NOT White/Blue, Black, or Red - (AC) - Any ignition coil or fuel injector
Speed Sense - White - (8P) - Unified Meter and A/C Amp, pin 26
Brake Wire - Pink/Blue - (+) - Brake Pedal Switch
Parking Brake - Purple/Red - (-) - Parking brake switch
Horn Trigger - Green/Black - (-) - Horn Switch
Wipers - Blue (L), Blue/Black (H) - (+) - Motor or IPDM E/R, gray 16 pin plug
Left Front Window (Up/Down) - Blue - Green - (A) - Driver window switch in door
Right Front Window (Up/Down) - Blue - Green - (A) - Passenger window switch in door
Sun Roof (Open/Close) - Blue/Black - Red/Green - Soft top switch on dash
Wiring Notes:
Can Bus High - Also found at the BCM in the driver kick, pin 39. The security light wire is Green/Orange (-) at the BCM in the driver kick, pin 23.
Can Bus Low - Also found at the BCM in the driver kick, pin 40
Power Lock - Meter this wire while turning the key in the driver door key cylinder
Power Unlock - Meter this wire while turning the key in the driver door key cylinder
Headlight - The IPDM E/R (Inteligent Power Distribution Module Engine Room) is between the passenger fender and the battery
Speed Sense - The Unified Meter and A/C Amp is behind the A/C controls in the center console
Wipers - The IPDM E/R (Inteligent Power Distribution Module Engine Room) is between the passenger fender and the battery
Left Front Window (Up/Down) - Extended triggers on the power lock/unlock wires will also roll the windows up/down
Sun Roof (Open/Close) - These wires are for the convertible top open/close. They only function with the ignition on and the brake pedal pressed.
Old 05-12-2009, 03:49 PM
adidasink
adidasink's Avatar
OK...I have looked all over online and on here and tried to go by the wiring color codes...but my 03 Z doesnt seem to match up.....am I missing something?
Yellow
Light Blue
Red/Yellow
Light Green
Gray
Gray (yes 2 of the same color)
White
Red/Blue
Orange (or orangeish brown)
Dark Green
Red
Pink
Green/Yellow
Black
Black/Red
Green/White
And I am trying to match them up to what is listed here and on other sites...cant quite figure it out...
HELP!!!!
Old 10-08-2009, 12:18 AM
kurtdaniel
kurtdaniel's Avatar
it really is a tough job..hope someone can help..but im sure that when it comes to wiring problems,, the autometer would be of great help in troubleshooting..
Old 02-28-2011, 08:40 AM
Hokie350Z
Hokie350Z's Avatar
At the speaker in the rear, which one is + and which one is -, all I can find is information on the wiring harness at the headunit
Old 03-21-2011, 04:19 PM
Suckapuncha
Suckapuncha's Avatar
nm, the Enercell 12v DC accessory i got was bad. i bought a new one and it works fine now.
Old 03-30-2011, 10:32 AM
Frank311
Frank311's Avatar
How about the plug on the passenger side. Any skamatic on how to put that back together?
Old 04-29-2011, 10:16 AM
Suckapuncha
Sorry haven't been back in a while...
I never took it apart. I just unplugged the harness going into the back of it, used the included wire splicers that came with the accessory, spliced them together, and then plugged the harness back in.
Old 12-20-2011, 06:29 AM
  #38
Ish99
Ish99's Avatar
This is the information i need but the pictures dont work, can anyone help me out. Im trying to hook up the wire from my Pioneer AVH4300 that lets it know the car is in reverse for the backup camera.
Red w/ Blue stripe
Old 01-31-2012, 03:20 PM
  #39
bmccann101
bmccann101's Avatar
uber old thread bump.. does anyone know what color wires in the doors that give the switch panels illumination - and + are?
I cant find anything for the life of me online, and im pretty darn saavy.
Old 04-15-2012, 08:09 AM
  #40
DJHowie
DJHowie's Avatar
i have the same issue. i know it's been outdated. just intalled a kenwood ddx7015 and the speakers are clearly not correct. these are the right colors coming from the car, not the ones mentioned in any of the guides. -___- help?
Yellow
Light Blue
Red/Yellow
Light Green
Gray
White
Red/Blue
Dark Green
Red
Pink
Green/Yellow
Black
Black/Red
Green/White
HELP!!!!
Quick Reply: Wiring Color code Guide for 350Z
