How to program garage door opener with rolling code to Home Link system
Old 02-18-2011, 03:20 PM
  #81
eatit
eatit's Avatar
Worked perfectly. I recently had all the garage door motors replaced(for non related reasons) and they were "rolling code" types. They had a very big and obvious "Learn" button on them.
Now I put my garage door remote back into my beater car where it will be there to stay!
After I programmed the Z, I went ahead and programmed my dad's Lexus IS250 homelink. It had the same EXACT procedures as the Z.
Old 02-18-2011, 04:07 PM
  #82
shakalaka
shakalaka's Avatar
I have two garages, can I set the homelink in a way that the different button opens the different garage door?
What exactly is the rolling door garage opener? I have those normal one's that you are in the centre of the ceiling. You press the button to open them, or if you're outside there's a keypad on the wall and you can enter the code on the keypad and press enter to open it.
Old 11-22-2011, 12:24 PM
  #83
trixal
trixal's Avatar
thanks for the info, worked great!
Old 02-26-2012, 07:03 AM
  #84
Humble_Z
Humble_Z's Avatar
Thanks bro, was easy to do....
Old 03-18-2012, 05:08 PM
  #85
shiru25
shiru25's Avatar
I dont have my garage door opener remote control, is it possible to program my Home Link system with out it, just with the garage door opener motor and the learn button, if it is possible, could you tell me how.. Thanks!
Old 03-25-2012, 02:11 PM
  #86
Kuhan
Kuhan's Avatar
Thanks for the diy, Vo! It worked perfectly.
Old 07-18-2012, 06:22 PM
  #87
torinme56
torinme56's Avatar
Default hi
I had to hold down the "learn" button for 30 seconds to clear the memory. Once that was done, I could program the HomeLink in our 2 cars along with the wireless keypad outside the garage for that opener.
internet marketing tips and strategy
effective internet marketing
Old 10-02-2012, 04:10 PM
  #88
CannMann21
CannMann21's Avatar
Ive got a Stanley 440 garage door opener. I tried doing this with the remote, but it didnt work. Then I realized the remote isnt the original one, its some skylink one...So do I need a stanley remote with my garage door opener to do this?
Old 11-15-2012, 05:42 AM
  #89
waldonlacey
waldonlacey's Avatar
Default How to program garage door opener with rolling code to Home Link system
Thank you for the useful information. It helps a lot to us. Allows you to open and close your garage door or turn inside lights on and off from the safety and comfort of your car.
dc garage door repair
Old 08-25-2013, 07:45 PM
  #90
HaOsLsE
HaOsLsE's Avatar
Recently got Z, I tried to program the Homelink...saw there wasn't a connection.
Found the previous owner for some reason had a connector in center console...didn't know what it was at the time. Went and bought wires to splice into connector...only to find original wiring in headliner LOL...so I spliced about a 6" wire on the connector for play...connect the 3 wires...then I saw lights and figured I was good.
Came here and found programming for rolling code....Worked PERFECT....1st try. Thanks for the great write up.
Old 11-13-2013, 03:09 PM
  #91
SoCal-Greenz
SoCal-Greenz's Avatar
BUMP good post I never press the button on the motor, Ill have to try this when Im back home
Old 10-20-2022, 07:02 AM
  #92
scoobiemario
scoobiemario's Avatar
I'm having hard time programming Homelink in my 08 Z to my Chamberlain B980.
Step3: When I'm holding both buttons, Homelink stops flashing and goes off at about 60 sec mark. And it does not program. I tried Canadian method as well (hold 2 sec cycle as well).
Clearing the memory works like described in the manual. Just can't program it....
etkms
06-19-2022 06:30 PM
lolwatbro
10-09-2021 04:58 AM
Siqcology
09-18-2019 01:45 PM
bcoffee20
11-19-2015 06:39 PM
Detailed Image
Cleaning & Detailing
09-18-2015 11:43 AM
Quick Reply: How to program garage door opener with rolling code to Home Link system
