350Z How to's
Old 07-25-2005, 05:47 AM
  #61
ephilyawjr
ephilyawjr's Avatar
Default Roadster Rear Speaker Removal
The Roadster is more tricky than the coupe to take out the rear speakers. You have to take apart the rollbar covers. Nissan in their infinate wisdom made the covers for the rollbars disposable. According to the manuel it shoes an X by the rollbar covers, which means these items are destroyed after taken apart. I took mine apart last night, and I was able to get them apart with only breaking one piece. The trick is to use a long screwdriver and try to seperate the pieces from under neath (inside the covers). The clips from the front cover are male and the back cover are female. The male clips have a locking clip that is facing down. If you push up on the clip, you can manage to romove the covers without breaking the clips.
With this Disposable rollbar cover, It is a good thing that Nissan put such a wonderful stereo in our cars so we don't have to worry about replacement. I hope the future models they actaully upgrade the Stereo even futher by putting in Jenson.
Old 08-07-2005, 08:53 AM
  #62
Paul350Z
Living in 350Z
Paul350Z's Avatar
The location of the speed pulse wire
https://my350z.com/forum/showthread....80#post1617980
Old 08-08-2005, 07:10 PM
  #63
Mark Matthews
Mark Matthews's Avatar
Default 350x factory radio wiring diagram
I replaced the factory speakers fron and rear with Polk Momo coax in the rear and Polk Momo separates in the front. I've added a Polk Momo 300.2 amp under the passenger seat. I've run rca's and speaker wire from the amp up to the radio. I ran 4 guage wire from the battery to the amp and graounded the amp to a bolt on the passenger side of the car. Now I need to know which wires to cut an splice for the fron speakers. I've looked on the web and on this site but can't find the needed information. Does anyone know which wires I'm needing to use? I also need to hookup the amps remote wire.
Thanks,
Mark Matthews
Old 10-10-2005, 05:55 PM
  #64
350ztoronto
350ztoronto's Avatar
very useful thread thx
Old 10-19-2005, 01:35 PM
  #65
ZlleH
ZlleH's Avatar
The How-to on the center dash is very detailed but it is on a car with no OEM Nav. Does anyone have any help for us that do have OEM nav and need to take the denter console off?
It's not as easy as someone said to pull on the navigation button faceplate and it will pop out. The Stock navigation faceplate looks to be one piece.
Old 10-19-2005, 07:19 PM
  #66
ZlleH
ZlleH's Avatar
Um, nevermind, I read the service manual and did what they said to do. get two flathead screwdriver, tape them up(as not to scratch the panels). Make sure one is big and the other one is a small flathead so you can fit it into the cracks.
1. Insert the smaller screwdriver wrapped with tape into the center square hole for the cluster lid D pawl. Bend cluster lid D backwardto create a front/back gap.
2. Insert another tapped screwdriver into the gap that step number 1 made and start to careful pry.
See below for pictures, hope this helps people who are in my situation.
Old 10-21-2005, 09:38 PM
  #67
antoz
antoz's Avatar
Default Have anyone modified their Nav. System to watch DVD?
I was just wondering if this is possible to do
Old 10-27-2005, 10:24 AM
  #68
Fletch69z
Fletch69z's Avatar
Originally Posted by srmd22
question: If you wire a detector into the homelink, will it power on and off with the car? And do you need any additional connections to the fusebox?
Yep.
Old 06-01-2006, 10:52 PM
  #69
Tsex On 19s
Tsex On 19s's Avatar
Great "how to's" Just installed my new head unit, and couldnt have done it without the help.. Thanks
Old 08-10-2006, 10:47 AM
  #70
dragone2717
dragone2717's Avatar
Would anybaody have a diagram or pics of how to remove the whole rear deck from a coupe. E edition 350Z?
Old 08-15-2006, 09:05 AM
  #71
Lsmith9523
Lsmith9523's Avatar
Hey guys, Take it easy on me,,for I just found this awesome website, joined and now I have a question? Could someone please post a "how-to" to take apart the dash to remove stock/install aftermarket head-unit? I saw a thread in first post,,,but for some reason, it is not opening on my computer..All other listed how-to's open just fine....Please help......Any would be greatly appreciated.....thanks.
Old 08-24-2006, 09:09 AM
  #72
reptile718
reptile718's Avatar
subscribing
Old 09-07-2006, 08:13 AM
  #73
pesci
pesci's Avatar
Looking for a link to How to remove the door panels.. This link is dead.. I need one for an 06
Old 09-08-2006, 10:45 AM
  #74
pesci
pesci's Avatar
I need help removing the door panels from an 2006 model. I tried to pull some parts off, but no luck. Anyone have a thread on this.. PICS WOULD DEF HELP !!!
Old 09-08-2006, 01:18 PM
  #75
bobstaff147
bobstaff147's Avatar
Default Broken link
The link to the remove door panels howto is broken. Does anyone have another link
Old 09-13-2006, 03:51 PM
  #76
djohn0240
djohn0240's Avatar
Does anyone know how to disassemble the door panels on an '06 Z Coupe? Everything I've seen has a different driver's side door panel and a different center console than mine.
Old 10-02-2006, 03:15 PM
  #77
tmtrino2
tmtrino2's Avatar
Default 06 removal of Bose Stereo?...
I have an 06 Grand Touring Convertible. I need to know how to take apart the dash so i can remove the Bose system and install a navigation unit. I click on the links that may be of some help, but none seem to work properly. I would appreciate anyones help. Thankyou
Old 11-15-2006, 01:55 PM
  #78
nothix
nothix's Avatar
Originally Posted by tonkadog
thread was removed
Old 12-17-2006, 04:00 PM
  #79
918 Z
918 Z's Avatar
how do u install an aftermarket shift light. its the raptor shift light, i had it on a spec-v but that got ran over so i want to install it on this car for when i go to the track. helps out alot when u have a big *** helmet on ur head. so, any how to's on a shift light install?
Old 12-18-2006, 09:06 AM
  #80
first350
first350's Avatar
not really to hard - you'll need to tap into the ECU's rpm signal (off one of the cylinders) and then get power (from HU or cig lighter)...then it's just finding a place to mount it. (I might do this install in the next few months...if I do, I'll post photos)
-Peter
Quick Reply: 350Z How to's
