350Z How to's
Old 01-10-2009, 10:36 PM
  #121
SmartDude
SmartDude's Avatar
Default Good question
I have an '08 automatic and I'm looking to install an iPod integration unit and a video adapter to my OEM nav screen. but i have no idea hot take apart the dash of an '08 auto w/nav. Anybody got a write-up?
Old 01-11-2009, 12:55 AM
  #122
350ZTheStandard
350ZTheStandard's Avatar
Originally Posted by farobaba
Thats odd, i thought I had posted it, but here it goes again;
Main website:
http://www.courtesyparts.com/
350Z catalog:
http://www.courtesyparts.com/350z-z3...c-714_715.html
Thanks for the link!
Old 01-11-2009, 06:42 AM
  #123
SmartDude
SmartDude's Avatar
Default what??
opps thought that was a link to a guide on how take apart the dash of an '08 auto with Navi. damn. good site tho.
Old 01-11-2009, 03:47 PM
  #124
SmartDude
SmartDude's Avatar
Originally Posted by draco10
Hey guys. It has been asked several times, but no one has answered it. So I would like to know. How do you take out the factory Nav unit out of a 06-08? Thanks.
http://integrationsolutions.net/RADI...6_REPLACE.HTML
found this link in a radio install from integration solutions
Old 03-05-2009, 05:42 PM
  #125
anny
anny's Avatar
Default thanks
thanks ,all the members who post here ,it is very useful!
Old 04-24-2009, 08:54 PM
  #126
fairladyzman
fairladyzman's Avatar
i'm trying to install new HU in my 03 350z and ran into problems... i followed the steps on wiring up the relay and all but have one question? what do they mean by wiring it up to the mute input of the new HU.....what wire is that? help me!!!-
Old 04-24-2009, 09:17 PM
  #127
fairladyzman
what do i do if i don't have a mute input wire?
Old 04-26-2009, 07:58 PM
  #128
farobaba
farobaba's Avatar
Skip that part, because it seems like u have a base model. But it doesn't make sense why a base model would not have the mute/attanuation wire since the harness are the same on all cars but i might be wrong. Does the cd player have a mute button on it?
Here is a picture of how to wire a simple relay, i hope this gets you closer.
Old 06-06-2009, 02:36 PM
  #129
sluggoZ
sluggoZ's Avatar
How do I remove the stock, bose cassette, 6CD & Radio unit to swap out for a replacement.
I have a '04Z.
Old 07-16-2009, 01:49 PM
  #130
ZKansasZ
ZKansasZ's Avatar
If I just want to replace the speakers only on a Z (with stock BOSE system), do I need to get any other adapter or things like that?
Or is it plug and play?
Old 09-24-2009, 10:55 PM
  #131
SnyzzleZ
SnyzzleZ's Avatar
any DIYs on how to run wires from sub/amp to h/u or change a h/u when you have factory NAV??? half of these links dont even work. I need help on this ASAP.
Old 09-27-2009, 01:39 PM
  #132
ambigu0us
ambigu0us's Avatar
How do I install an aftermarket Navi in a '04 Touring w/o Navi -- specifically -- Speed Sensor, Reverse and Parking Break connectors??
Old 11-17-2009, 12:30 PM
  #133
shredZ
shredZ's Avatar
Default Air/Fuel Gauge install
Can someone post on where to connect the wires for an air/fuel gauge on a 08 350Z...thanks!
Old 11-17-2009, 02:19 PM
  #134
BakaN20
BakaN20's Avatar
I have a '04Z.
Go to 350z tech, there are diy there.
You need a spacer for the fronts. Most aftermarket speaker magnets are larger and will hit the glass when it goes down. You can cut out your old speakers and use them as spacers.
Parking brake, what kind of unit do you have? You can probably just ground it, reverse you can tap the reverse lamp wire. Don't know about the speed sensor.
Do you have an aftermarket wideband? Or are you trying to tap the stock o2 sensors. If it is stock o2 sensor, unless that gauge can read 0-2v, i don't think it will work.
Old 01-24-2010, 12:01 AM
  #135
350ZTheStandard
Does anybody have a link to remove the the OEM seat covers, I am changing out my OEM leathers for new leather and any help would be great. Thanks in advance
Old 02-18-2010, 08:07 PM
  #136
trusovici
trusovici's Avatar
Default Bose rewire
To everyone interested in what to do about their bose this is it:
if you have it and want to continue to use the speakers but replace the headunit, you must purchase a bose interface unit or something like that. if you want to replace speakers, you must replace the headunit and rewire the whole cars audio system. aftermarket speakers are a 4ohm impedance while the bose system is designed to operate with a 1.3 ohm load, and the actual bose wire is a weird sheilded non-conventional type of wire. i learned this a long time ago on my old bose maxima. that was a lot of wiring! the 350 shouldnt be too bad being a small car and you dont need the rear speakers anyway.
Old 12-15-2010, 01:45 AM
  #137
cole_nattermann
cole_nattermann's Avatar
This is probably a dumb question but I just got an 03 Z. not sure what submodel but it has the simple CD player (not bose or anything). I'm wondering if there is anyway to add an Ipod to that system? not sure if there is an input, or if there is a way to directly wire it in. to me the stock player just fits to damn perfectly to mess with.
Old 12-20-2010, 01:43 PM
  #138
SmartDude
SmartDude's Avatar
Cool ipod solutions
There's no easy way to hook up an iPod connection. If you want a direct connection, you are gonna need an iPod solution thats designed to work with your OEM stereo. But to install it you are going to need to take out the center unit anyway. Its kind of a pain in the a$s. There are walkthrough guides online. The key thing is to be careful, try not to scratch up any part of your interior or face of your stereo and try not to break the plastic parts that are designed to snap together and hold the center console in place.
There are numerous threads detailing the pros and cons of each ipod solution just search my350z.com for my posts to find them.
Old 05-05-2011, 07:58 AM
  #139
isalvus
isalvus's Avatar
Default Good tread
The how to's are very helpful thanks
Old 07-08-2011, 12:11 PM
  #140
03Platinum350z
03Platinum350z's Avatar
Im looking for a how too dynomat the sh*t out of the Bose sub enclosure area! Ive heard some people use clear silicon to close up any holes in the enclosure, then dynomat over that then use hepa tape to make sure it is air tight! Anyone help me out on this one? Have all my shiz to take the crappy Bose sub out and replace it and want to find the best option!
Jeff
Quick Reply: 350Z How to's
