How do I Connect a 12V constan and Switched wire?
on
Hi All,
I bought a AUXNISSv3, One plug plugs into the stock non bose head unit's CD changer (2004) and it has two other wires,
A. (Yellow) Wire connects to a +12v Source
B. (RED) Wire Connectes to a switched 12v Source
What do i plug these into in the 350z?
Can i splice the factory head unit wires, and if so which ones to i splice?
any help would be great, thanks!!!
http://www.discountcarstereo.com/pdf/auxniss.pdf
you need 2 conections witch are commone to any electrical install.
1-constant 12v
2-ignition 12v
the first one is ware memory and settings are saved and its always gets power from the batery
the second source tells it to turn on and uses power for normal operations
I would look into the manuel to dbl check but I beleive the power constant is yellow and the ignition power is red in the stereo wire harness. if not u can always splice into your ignition wires for ignition power and have a direct conection with a fuse to your batery
1-constant 12v
2-ignition 12v
on
which wires would i splice from the factory radio harness?
(and i am sure about the colors, i linked the instructions)
Does the stock radio harness have both wires to splice into?
on
thanks for the link!
pictures of the harness
so the yellow is the Constant 12v Power correct?
Which one do i plug the ignition 12v into?
Radio Ignition lt. green???
[quote]
Radio 12v
yellow
radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
[\quote]
[quote]
Radio 12v
yellow
radio harness
[\quote]
on
Yeah, as these guys mentioned...
OR... to keep things neat and "pretty," just buy the Nissan wiring harness ~$6-7 shipped from ebay for 95-up Nissans, and splice into the two (2) wires mentioned before. This way, you don't mess with any of the "OEM" wiring.
on
i still need to plug in the wiring harness to the stock radio, so a wiring harness might not be useful??
I am just trying to get power to the AUXNISSv3
Administrator
God these n00bs have it easy! When I 1st bought my Z in February 2003, I had to use a Fluke meter to figure out what all the pins/colors were for. Now there's convenient little stickies for all you guys. Fawk!
Nevermind me, just releasing some hot air.
on
yup, i am a super noob, never messed with wires before
Administrator
on
i connected the AUXNISSv3 to the 12v yellow wire and the light green wire on the back of the radio and it didnt work
i think that the light green wire isnt 12 volt
any idea where i can get a 12v switched wire from ??
please help?
please help?
Administrator
please help?
please help?
350Z_Al
10-29-2020 07:44 PM
04-04-2016 07:52 AM
