AVIC-D3 Install Guide
#61
on
i tried connecting the blue w/ blue/white and it's not correct. i believe it's #1 and #3 from your picture. it makes more sense if you ask me. i just haven't gotten around to fixing it.
#64
excellent! 1 and 3 it is.
i did my install today and i cant believe how smooth it went!
radio signal is great, ipod control is amazin as well works a lot faster than my kenwood.
btw for you guys with the hazard button under the AC controls, dont forget to plug the connector back in. its really tiny and you miht miss it. i did and i had to go back and plug it in.
thanks for the help guys!
one question on the nav.
i programmed my address for teh home button,but on the map it is off by about a block, is this normal?
everything else works fine, directions are right to the point.
#66
on
Will the Metra harness 70-7550 work for the 07 models? All the sites I see have it listed as 03-05.
Also, will this harness also work with the AVIC-Z2?
#69
on
i'm getting a screen that says "inproper connection of the ebrake, check your wires " or some crap like that at every start up. I haven't even tried if my dvd works like it should. I followed teh guide. Is this normal?
**edit* i think i forgot to ground the yellow mute wire after relocating it on the harness. I'm going to try this tomorrow.
#73
on
also, what goes to ground # 2?
for the main ground ( # 2 like said ) its the black wire?
Can somebody just verify with goes to ground 1,2,3 ....thank you
#74
on
one more question LOL
the pink vehicle speed control wire from the power harness into the VSS wire.....so do i complete cut off the end of the VSS wire and splice in into the white wire?
#75
leave it where it is. peel the insulation a little on the VSS and solder the wire from the head unit to it. or get one of those little plastic things designed to tap into wires from radioshack.
these are NOT the actual wires but the idea is to get something like this.<img src="http://workmanship.nasa.gov/lib/insp/2%20books/links/sections/graphics/616/616-03.gif">
#76
on
