Installing Navi 2 amps 4 speakers and a sub
on
This forum rocks! Ive already done my install on my G35, but my friend and I are tackling his 03 350z, Ive done the navi already, currently running the power wire.....This is where im lost.
I cant find the link on how to take apart the area where the sub is.
I dont know which wires to take from the harness in the rear of the car to route to my 4chan amp. (where the factory bose amp is, i want to tag those and route them to my 4chan)
Im also looking for a link to make my front speakers fit, (like make a wood speaker spacer)
If anybody can help that would rock!! Thanks and much appreciated!!
on
still need the disassemble of the back/bose sub area
still need how to on door spacers
but found color codes....second sticky
category color polarity location
12volts white/blue + ignition harness
Starter white/red + ignition harness
Second Starter white/green + ignition harness
Ignition black/red + ignition harness
Accessory white/black + ignition harness
Keysense black/red + ignition harness
Power Lock red - driver door module in door
Power Unlock lt. blue (double pulse) - driver door module in door
Lock Motor purple 5wi white plug, pin 30 at BCM
Unlock Motor yellow 5wi white plug, pin 23 at BCM
Disarm Defeat white/red 5wi white plug, pin 31 at BCM
Parking Lights+ red/blue + driver kick panel
Hazards green/red - brown plug, pin 61 at BCM
Turn Signal(L) green/white + white plug, pin 22 at BCM
Turn Signal(R) purple/white + white plug, pin 21 at BCM
Reverse Light lt. green + driver kick panel
Door Trigger white (L), pink (R) - white plug, pin 14, 10 at BCM
Dome Supervision comes on with unlock
Trunk/Hatch Pin red/white - white plug, pin 18 at BCM
Hood Pin lt. green/black - hood pin switch under hood
Trunk/Hatch Release pink - brown plug, pin 76 at BCM
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil
Brake Wire pink/blue + brake pedal switch
Parking Brake purple - parking brake switch
Horn Trigger green/black - steering column
navi:
Speed Sense white 8P Unified Meter and A/C Amp, pin 26
The Unified Meter and A/C Amp is behind the A/C controls in the center console.
audio:
Radio 12v
yellow
radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
navi:
audio:
Radio 12v
yellow
radio harness
and you can find the rest in the 5th sticky. 350z how to's
hear is door panel
https://my350z.com/forum/showthread....&threadid=7995
rear speakers
https://my350z.com/forum/showthread....threadid=26837
after removing the rear panels you should be able to tell how to dissemble the plastic to get to the sub plate.
hear is door panel
rear speakers
on
after re reading 2nd sticky, it didnt actually help me with the bypassing of the factory amp. i found some pdf from 350 z tech .com place that had info of which speaker leads to grab from the amp harness in the hatch of the car(pins 19-26).
i read all 5 pages of sticky number 5.
Voboy- the rear speaker install doesnt actually show how to take off the entire area of the back where the bose sub is. im 90% done with that disassemble by just jumping in to it. I cant figure out how to take off the damn cigarette lighter.
I appreciate you helping me, you are the only one so far and hopefully i finish tonight. Just need to find the how to make speaker spacers and now how to take off cigarette lighter.
on
Not sure what you mean by take off cigarette lighter. you can just unplug it and leave it in the plastic finisher to remove the panel from the car.
As for spacers, it's not a proprietary 350z thing to make spacers, it should be common audio install knowledge. Here's a couple overview steps:
*cut a hole in MDF the diameter required by your mid/woofer.
*use the OE plastic housing to trace the shape of the outside including the screw holes that mount the plastic housing to the door. Make sure that the hole you cut in the MDF is in line with the mid/woofer hole in the plastic housing.
* cut out what you just traced, and drill the screw holes.
* screw MDF spacer to car, use gasketing tape or gasketing caulk to assure an airtight seal.
* screw mid/woofer to spacer, use gasketing tape or gasketing caulk to assure an airtight seal.
on
Figured out everything, thanks for the help kind of.
StreetOC192- I appreciate the input, i was told by plenty of people that i need spacers, i havnt tackled the doors yet, but i went out and got universal spacers for a few bucks, if they dont look right ill use the rest of the wood i used for the amp rack as mdf spacers. thanks! i thought the spacers had to be something more special.
on
Originally Posted by joe645733
tackle the doors hard.
just did!!
thanks! they werent actually too hard. i used the store bought spacers and some dynamat. worked fine.
thanks for reading
on
Sure ill post em tonight, I didnt take any during the process, but ill take a few when my roomate gets home. the kenwood 7100 fits nice in the 350s dash, i put the amps where the bose sub was, routed the rcas/remote wire through the center and the power wire on the pass side door.
in the mean time here is my car:
