How much of a sound improvement do aftermarket speakers yield?
on
So I have an 08 Nismo and have installed the JVC Arsenal KW-NT1 (a great system, BTW) and it replaced the stock non-Bose single CD head unit. I did not replace the stock tweets or the non-Bose stock Clarion speakers (which can handle a surprising amount of bass).
I am considering replacing all four speakers with 6.5" Polk DB651 (which also comes in a shallow mount version which I'm pretty sure I don't need; I know many here just replace the front two and don't bother with the backs but I like the surround effect I get from DVDs so I'm replacing the back speakers as well) and I have NO desire to install an amp (it uses too much power and weighs too much; I want to one day turn the Nismo into a track car).
My question will installing the Polks sans outboard amplifier yield a noticeable sound quality improvement over stock? Also, I was just going to keep the stock tweets because I've heard installing new tweets is a pain because of the drilling required but should I go ahead and do that as well? Thanks in advance.
Living in 350Z
IMHO the single biggest improvement you can make is changing out the speakers for something you have listened to and like. Speakers have the biggest influence on the sound more than everything else, the cabin would be a close second. I'm not personally familiar with the 6.5" Polks but they're likely much better quality than the stock speakers. People have different tastes in music and different speakers sound differently. Grab a CD of your favorite tunes and find a store to listen to your prospective speakers.
on
I would go with Bostons or Alpine. I recently got bostons and moved the alpines in the back and boy it made a world of difference. I would recommend getting the same speaker all the way threw. My way was 2 years apart :/(not a good idea) You can get 4 channel amps that dont weigh that much honestly and plus you would get the most sound for buck with a small 4 channel amp. Just my 2cents
on
imho the single biggest improvement you can make is changing out the speakers for something you have listened to and like. speakers have the biggest influence on the sound more than everything else, the cabin would be a close second. I'm not personally familiar with the 6.5" polks but they're likely much better quality than the stock speakers. people have different tastes in music and different speakers sound differently. Grab a cd of your favorite tunes and find a store to listen to your prospective speakers.
Former Sponsor
on
on
Thanks for the replies. I've heard the Polks in person and they sounded very good (but they were driven by a Kenwood HU and outboard amp). The problem is there is no way to hear how they sound with my JVC HU unless I buy and install them.
I'm pretty certain that I will pull the trigger and do it. The speakers are $35/pair on Amazon and that ain't bad.
on
on
JVC Arsenal subs
JVC Arsenal subs are made of... marijuana.
http://mobile.jvc.com/arsenal.jsp
http://mobile.jvc.com/hemp.jsp
FWIW I got a 10" and it's smokin
It rumbles in a really good way.. haha
The 6.5" Polk DB651 is an inexpensive coaxial speaker that has a quality build, and it will be fine with just the JVC KW-NT1 H/U’s built-in amp. This speaker will sound very good even when driven by a low power amplifier. In fact I doubt you will get much benefit with a more powerful external amp matched to this speaker. This model is designed for less power.
--Spike
on
Thanks for the replies, folks. I'm not a big fan of Boston speakers because just like their home speakers, their car speakers sounded too bright and "trebley" to me. Also, I've heard the Alpine Type-S and Type-R speakers and while they sounded good, they didn't sound measurably better than the Polks to justify the higher price.
So I've ordered the Polk 651 and the component 6501 with 2 tweets, 2 woofers, and 2 crossovers from Amazon (for an absolute steal) and I'll post a review post installation and break in.
^^ For sure… If you are replacing the cheap stock Clarion fronts with 6.5" Polk DB651 coaxials.
You will notice a significant improvement, even if you just drive the Polk’s with your H/U’s internal amp.
--Spike
--Spike
sorry OP I'm not trying to thread jack but I have a question relative to speaker quality. I have the BOSE system. I am changing to an aftermarket JVC headunit. I have heard that with the BOSE system that there is no point in changing the component speakers because they are powered by the BOSE amplifier and will not sound any better at all compared to the standard Z system which runs the components off of the Clarion headunit. Is this true? Should I not bother with aftermarket component speakers?
on
Also, I understand why people wouldn't replace the rears, but they *do* make a difference imo. They're also a PITA to replace and if I'm working alone and my car doesn't want to cooperate they take about 2-3 hours to install. Most of that time is spent bitching at not being able to remove the plastic "hump".
For my tweeters I just replaced them and wedged them in there. There really wasn't much work to it other than making sure the factory tweeter covers didn't come off.
^^Just my 2 cents from my experiences.
