backup camera, new option...
Old 10-15-2010, 10:07 PM
  #141
dcains
dcains's Avatar
CMOS sensors will overheat and become noisy if powered on for too long, so that's why you were getting a "cloudy" image. In the daylight mine is very clear, but the image does get noisy in the dark. Still works more than well enough, though, and I can easily see the area illuminated by the backup lights. Get the brightest LED backup lights you can, and it will work even better.
I ran my power/signal wires through the opening the backup light clips into. With the right taillight off I was able to fish a coathanger through the grommet on the rear trunk wall to grab the wires and pull them through. This way you can't see any wiring, and all the connections are made inside the car, so they're not exposed to the weather. There are a bunch of options on how to run the wires once they're inside the car.
It looks like the distance markers are in meters, at least to me.
Old 10-15-2010, 10:11 PM
  #142
Linuxglobal
Linuxglobal's Avatar
now it makes sense, i just wanted to have the option to turn the camera on during traffic or for my other car when i tow stuff but i guess it would need a separate power switch or something if that was the case.
So what would be better for future reference, CMOS or CCD? Would the CCD have better nighttime resolution?
As for the wiring, i actually found the green reverse cable in the big cable wrap going across the rear of the car and tapped into it. That way i dont have even more cables going out. The reverse wire is a solid light green color with what appear to be silver squares.
Old 10-15-2010, 10:15 PM
  #143
dcains
dcains's Avatar
You could certainly add a separate power circuit with a manual switch, but you'd want to isolate it from the backup light circuit with a diode. That way you'd still have the camera come on automatically with the backup lights, and have manual control, too.
That green wire in the trunk is definitely the best way to go for minimal wiring.
Old 10-15-2010, 10:21 PM
  #144
Linuxglobal
have you tried any ccd cameras? im debating to buy another one to see the difference between them
The ccd is twice the cost but im not sure if anyone has seen a difference between the two or how they compare
Here is the link
http://cgi.ebay.com/ebaymotors/NISSA...#ht_4515wt_958
I would be happy if it was just clearer
Edit: Ill wait another month and take pics of the CCD vs CMOS I just ordered the CCD one for 90$ shipped so ill see how it works out. Anyone want a CMOS camera after im done?
Old 10-16-2010, 09:06 AM
  #145
dcains
dcains's Avatar
I couldn't say which is better, but I guess you'll find out soon enough. Post some pics.
Old 10-16-2010, 10:11 AM
  #146
Linuxglobal
i went through a few comparisons on the BMW forums and they claim the CCD is clearer in both night and day situations. I dont have mine running all the time but apparently the ccd doesnt get flooded by bright lights at night like the CMOS.
Here is the article looking at the camera technology alone
http://shop.reversingcamerasuk.com/C...-sensor-CAM004
BTW for the time being, here are my install pics and output shots
Installed
Ill get a nighttime shot tonight, but its gonna be terrible
Old 10-16-2010, 10:39 AM
  #147
DavesZ#3
DavesZ#3's Avatar
Hmmm. Interesting.
Yours:
Mine:
I wonder if you received the exact same camera that I did. Maybe they changed the programming of the lines in the last week or two. I'm guessing the measurements are still meters though.
Try taking a shot like mine where I put two sticks on the ground in line with the outside of the wheel track (or draw chalk lines). I'm curious to see if the passenger side install woudl correct the offset problem that my driver side install shows.
Old 10-22-2010, 06:00 AM
  #148
slmdchvy05
slmdchvy05's Avatar
quick note about the install, im using a pioneer avic d3[/B]
1. installed it in the right (passenger side) plate light. It looks more oem in that position imo and the image doesnt look too offset. Plate lighting is also a lot more even this way
2. I ran the cables through the rubber gourmet behind the plate, you have to remove your license plate and then you will see it quite clearly. I had to cut a small hole in the rubber gourmet and then I used permatex black rtv gasket maker to cover the junction and seal up the new and old cables so water doesnt enter through that opening.
3. Ran the other cables through the side pillars and roof liner around the driver's side.
4. One more note, the little distance legend is maybe in feet? or inches LOL Mine are blue and i have every number from 1-4.
If anyone has any other issues ill try to help as well. Shipping from China was a crazy wait.[/QUOTE]
I have the pioneer avic d3
with the back up camera hooked up but the picture is reversed. things on the right of my car are on the left vis-a-versa. can anyone help with this problem
Old 10-22-2010, 06:49 AM
  #149
DavesZ#3
DavesZ#3's Avatar
^^^ Your HU needs an option to flip it. The camera doesn't have one.
Old 10-22-2010, 05:50 PM
  #150
EvanV
EvanV's Avatar
Hey guys,
Finally got a chance to wire everything up front as I had the day off. HUGE Thanks to dcains for helping me with some wiring issues and questions. Really appreciate it.
Here are the pics:
Attached Thumbnails backup camera, new option...-350z1.jpg   backup camera, new option...-350z2.jpg   backup camera, new option...-350z3.jpg
Old 10-22-2010, 09:29 PM
  #151
Linuxglobal
hi slmdchvy05
the camera is at fault if the image is not flipped, the unit simply displays the image (in the case of the avic D3).
I tested my cameras beforehand and they both had mirrored displays (on my PC).
Hope that helps
C
Old 10-22-2010, 09:34 PM
  #152
Linuxglobal
Some updates
Installed the CCD camera today, it was 90$ shipped but it arrived here in 4 business days
I didnt have time to pull out my camera, but clarity is NIGHT and DAY !!! Way sharper than the CMOS and its really clear and bright at night, no more fuzzyness
Ill snap daytime and night time pics tomorrow.
From my observations
CCD
- same resolution as CMOS
- auto light adjustment
- reacts better to light sources, doesnt get flooded by flashlights/car headlights
- great for nighttime use (so far)
- no gridlines available on ccd
- no issues being powered for over 30 mins
CMOS
- same resolution as CCD
- heat issues, does not like being on for longer periods of time
- easily flooded by other lights source, very blurry at night/pixelated
- usable at night but not as clear as the CCD
- daytime use is ideal and very good
Pics of the CCD to follow
Cheers
C
Old 10-23-2010, 05:39 AM
  #153
dkmesa350z
dkmesa350z's Avatar
Originally Posted by Linuxglobal
Some updates
CCD
CMOS
Cheers
C
Look forward to the comparo pics. My $30 Pyle cameras keep dying.
Old 10-27-2010, 07:32 PM
  #154
slmdchvy05
slmdchvy05's Avatar
Is there any way to flop the pic on my back up camera. I talked to a few car audio places and they mentioned to me that I should try and reverse the wires from the camera to my pioneer unit. Any suggestions on what I should try and do before I ruen a cheap set of wires. Lol I just want the pic to be right because it throws me off when I'm backing up at night due to my dark windows.
Old 10-27-2010, 07:41 PM
  #155
dcains
dcains's Avatar
If your HU doesn't have a switch for this, you're SOL. Changing the wiring isn't going to flip the image, and could very likely do some permanent damage.
Old 10-27-2010, 07:45 PM
  #156
Linuxglobal
i got it installed, its been good so far. Im just stuck at school marking papers until late tonight. Ill try to snap some pics tomorrow before i leave the house.
I cant comment on reliability. I had the CMOS in my car for maybe a few days, then the CCD arrived 4 days later and i use it 2 mins every day
Nighttime is well worth it tho, very nice and crisp, very sensitive too
Old 10-31-2010, 07:38 AM
  #157
EvanV
EvanV's Avatar
Hey Linuxglobal,
Any update on the pictures?
Old 10-31-2010, 09:01 PM
  #158
Linuxglobal
The camera doesnt make it look all that great but it may be the avic d3 screen as well that is a bit pixelated.
I made a quick video too of me backing up. Ill post it up shortly as soon as it uploads.
Daytime pics coming soon. I get home when its dark now all the time.
C
Old 10-31-2010, 09:05 PM
  #159
KingBaby
Hardest Setting
KingBaby's Avatar
Got mine the other day and for the price it's perfect...
Old 10-31-2010, 10:18 PM
  #160
kevincat
kevincat's Avatar
i hate the fact that it cuts of half the light emitting from the right side. it makes it look weird, i might just use electrical tape to tape off the other side to make it look even.
Quick Reply: backup camera, new option...
