Low Volume with Aftermarket Head Unit
My buddy who used to be an installer did my Pioneer DD and when he had finished wiring everything up I had the same issue. He ended up splicing RCA's and somehow wired them to the blose stock speakers. I can't get my radio over 9 or 10 it is so loud now, before you had to get o like 30 just to hear it. Wish I could tell you exactly what he did but I can't. I am going to his place tomorrow so if you still can't figure it out I will see why I can find out.
You need the PAC ROEM-NIS2 adapter. One end is plug and play into the car harness and the other end is wired to your car stereo.
Your problem is normal for those who are using an aftermarket radio on a stock Bose system. The audio wont be loud enough from your new headunit and you may hear a buzzing from the different levels coming from the Bose amps. PAC ROEM-NIS2 will fix that.
I'm using one myself on my Bose system and everything works great.
I actually think the sound quality is perfect just the volume level is highly low. There is surprisingly no hissing or alternator whine. Even when I then the car off and on its very quiet.
But I will have to get that adapter I suppose as that's the only way to get the volume louder.
I don't have the PAC or the metra and my car runs my pioneer with stock blose and actually sounds decent. Loud and clear. I will see what I find out for you tonight and update this as early as I can tomorrow.
"This is indubitably an issue with your speakers. You should check all speaker connections to make sure they are secure in order to ensure they are able to produce optimal volume. You should try sending this into a professional to get looked at. This will be your best bet."
I emailed sonic electronix where I bought the unit from and they said its a speaker issue.
They clearly have no idea what they are talking about.
Its worth the 30 bucks. Its "indubitably" a wiring issue at the head unit.
A chassis ground to amp ground? what? The amp shouldn't have been touched during a headunit installation, so theres no need to screw with that ground. The headunit could have had a bad ground which can cause issues, so if you want to take it out and see where its mounted thats an option.
I didn't touch the amp at all. On the head unit there is an amp ground that goes to the harness I grounded those together. Same with the regular ground from the head unit to the harness.
I can try to do a wiring diagram and show how I did it
Hmm.. I don't remember having to ground all those wires. I'm pretty sure all I did was ground the black ground wire coming from the head unit, without connecting it to the harness. Amp ground can probably just be capped and left as well. Don't know if that would make a the difference or not though.
You don't need an amp ground at the head unit though. Doesn't make any sense.
I am going through the same problem. I have a 2007 Nissan 350z bose with nav. I have metra 70-7551. Whats the best way to get the sound back up. Ive read a few diffrent ways but none for my year. Any help would be great. Ive heard you can ground wire or do i have to buy that pac harness?
