Just ordered a Kenwood DDX470!!
Old 04-21-2014, 06:34 PM
  #141
CynicalSaint
CynicalSaint's Avatar
Originally Posted by bobinsofla
Where did you ground your parking brake wire to? What location?
Thanks,
Bob
I just connected it into the other ground wires in the wiring harness. Worked like a charm.
Old 06-13-2014, 06:54 PM
  #142
DarkCreep
DarkCreep's Avatar
Thanks,
Bob
One of the 10mm bolts holding down the shifter bracket/plate/whatever.
You guys see that this is discontinued on crutchfield? I wonder what replaced it.
Old 06-13-2014, 10:45 PM
  #143
dcains
dcains's Avatar
Ddx471
Old 07-07-2014, 05:35 PM
  #144
jp0065
jp0065's Avatar
Default Kenwood DDX470
Does anyone know if you can stream apps like netflix and youtube to the Kenwood DDX470 using an android device? I know you can do it with and iPhone.
Old 07-08-2014, 06:24 AM
  #145
CynicalSaint
You can't. You can't even do it by USB. Something about the file method of android is not compatible with the DDX470. The only thing you can do with your Android phone is receive calls, and play the music you have stored on it over Bluetooth. No other apps or functions work.
Old 07-08-2014, 01:22 PM
  #146
dcains
dcains's Avatar
Actually, there is a Garmin GPS app which mirrors the iPhone screen, but that's the only one I know of.
Old 07-18-2014, 01:23 PM
  #147
DarkCreep
DarkCreep's Avatar
Spotify, I heart Radio, Milk Music, etc do work in bluetooth method and show artist name and song similar to pandora.
Im sure you *can* get it to work if you got an RCA to HDMI to MHL then connect a Samsung or other MHL phone.
Personally, not worth the trouble. I want to watch Netflix comfortably at home, not while driving a 1.5 ton vehicle at 70mph.
Old 07-18-2014, 02:25 PM
  #148
CynicalSaint
[QUOTE=DarkCreep;10427537]Spotify, I heart Radio, Milk Music, etc do work in bluetooth method and show artist name and song similar to pandora./QUOTE]
I will have to try those, I couldn't even get Pandora to work.
Old 07-21-2014, 09:53 PM
  #149
DarkCreep
DarkCreep's Avatar
[QUOTE=CynicalSaint;10427569]
Go into the settings of the bluetooth, theres a setting that "turns on" the pandora, phone call, and bluetooth feature to connect to your phone. So technically, everything else could work but if Pandora is checked off it wont work. Stupid setting if you ask me but its there. Make sure Pandora is on and youll be fine.
Another one is the speaker set up. All 4 speakers work but if you have it off during bluetooth, only the fronts work. It annoyed me for the first few weeks I owned the unit till I found the setting.
Old 07-24-2014, 10:19 AM
  #150
JCat
JCat's Avatar
I'm going to be running 4 Alpine 6.5 4ohm coax speakers with this unit, and a JL JX1000/1D amp driving 2 10W3v3-4's
Question:
Those of you that are using this unit with a 4 channel amp . . . . are you glad you went this route ? or would you suggest that the Kenwood head unit (alone) output more than enough ?
Old 07-24-2014, 12:04 PM
  #151
dcains
dcains's Avatar
Question:
I've used mine with and without a 4-channel amp. But, always with a separate mono subwoofer amp. In that case, the internal amp on the Kenwood did pretty well, because it had plenty of power for the main speakers once the drain of the low frequencies was handled by the separate amp and sub. I've only got a single 10" JL sub and 250W JL mono amp. The full range speakers also perform better, for the same reason.
So, in your case, I think you may be OK. Try it and see. I've never been interested in bass to rattle the whole car, and I think my system is very well-balanced. You my have a different idea of what sounds good.
Old 10-06-2014, 10:42 PM
  #152
DarkCreep
DarkCreep's Avatar
dcains do you have coax or comp. speakers?
I have Polk Audio DB651s powered by radio in the front with stock speakers in the rear. The SQ is great and highs sound good but I really want to get some component speakers and move the DB651s to the rear. I cant stand the way the rears sound, luckily the fronts drown them out.
Also, if I run wires straight from the radio to the speakers (bypassing the amp), will they be louder? I put a Kenwood radio into my girls '05 Altima with stock speakers and base notes hit way harder than my car and I have the Bose poor excuse for a subwoofer. Her mirrors even rattle and everything!
Old 10-07-2014, 07:14 AM
  #153
dcains
dcains's Avatar
I can't recall the model numbers, but I have Boston component speakers front and rear. Here's are a few pics of the rear tweeter install, while the fronts are installed in the original location:
Not sure I understand your question about the wiring. If the speakers are wired to an OEM Bose amp, they will IMO sound better wired directly to the Kenwood HU's internal amp. But, I can't say how they will balance with the Bose sub, if that's what you have.
Old 11-14-2014, 12:47 AM
  #154
DarkCreep
DarkCreep's Avatar
Yeah I have the Bose sub.
Love your tweeter placement btw.
Im going to hard wire my next set of speakers and hope it sounds cleaner and maybe get a little more bass out of it.
04-22-2021 09:42 PM
ablaine
11-29-2016 10:13 AM
dcains
11-11-2015 11:36 PM
350z82
10-01-2015 06:25 PM
Quick Reply: Just ordered a Kenwood DDX470!!
