Wrieless reverse/backup camera wiring advice
Old 04-18-2014, 10:53 PM
djcalle
djcalle's Avatar
Default Wrieless reverse/backup camera wiring advice
Hey guys,
I’d like to install a wireless backup camera. My main goal here is to avoid running wires from front to back.
I would power the camera from the reverse light.
Question is where can I tap in the reverse light power cable so the HU switches to the backup camera input when I’m in reverse?
I read that people run cables from the HU to the rear of the car, but surely this could be done at the front?
Any input would be appreciated!
Cheers,
Ludo
Old 04-19-2014, 09:29 AM
beezee
beezee's Avatar
From the wires at the reverse light itself.
Remove the panel in the trunk for easy access. I think the color is light green. I did mine a while ago. Just test the wires while someone puts the car into reverse.
Stand on the side just in case car moves
Old 04-19-2014, 05:56 PM
djcalle
djcalle's Avatar
Thanks Beezee, but surely the same wire should be accessible not too far from the Head unit? I do not want to run a wire to the back of the car.
If no one has tapped in it around the front of the car before I might need to trace it out from the fuse box.
Old 04-19-2014, 07:57 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
my advice is to NOT install a backup camera...unless it comes from the factory, people who install these are tools...
Old 04-19-2014, 07:58 PM
BranZ
BranZ's Avatar
Seriously? ^
Could possibly have a nominee for poster with the stupidest comment ever on this site.
Old 04-20-2014, 03:05 PM
johnx818
johnx818's Avatar
Light green on DEs (not sure if it's the same for HR) in the driver's side kick panel. There's a thick harness with black wrap, cut that open and find your light green wire.
Edit: Make sure you test the wire..
Old 04-20-2014, 04:30 PM
djcalle
djcalle's Avatar
Thanks John!
What's the best and less intrusive way to test the wire? splicing?
Old 04-21-2014, 11:37 AM
johnx818
johnx818's Avatar
Thanks John!
DMM or test light, test the wire for +12 volts when you put your car in reverse.
Old 04-21-2014, 10:15 PM
djcalle
djcalle's Avatar
Cool, I have a multimeter, I was just wondering about the less intrusive way to test the wire without butchering it
Old 06-12-2014, 04:14 AM
djcalle
djcalle's Avatar
Hey John,
Found this picture from another post, do you happen to know which harness to cut into to get to the light green cable? I'd like to avoid trial and error on this one . There's also an exposed light green cable going straight into that black box, I'm assuming this ain't it?
Old 06-19-2014, 09:58 AM
johnx818
johnx818's Avatar
Hey John,
I'll check when I get off of work
Old 06-19-2014, 07:08 PM
johnx818
johnx818's Avatar
The light green wire will be in one of those two wrapped up wire harnesses. It's in the one that is running to the rear, which should be the one on the left.
Old 06-19-2014, 09:10 PM
djcalle
djcalle's Avatar
Awesome! Thanks for checking John. I received my camera, went for wired instead. I'll start the work this weekend and report back if I find anything worth sharing,
Old 06-20-2014, 09:09 AM
johnx818
johnx818's Avatar
You're welcome. Good luck and take your time!
Old 10-01-2014, 09:44 AM
mnfmkf
mnfmkf's Avatar
Did you finish your back up camera install ?
How did it go ?
If you can give me a idea of how the process went let me know.
Thanks
Mike
E mail. Mmforeman@fronteir if you wish
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
350Z_Al
10-29-2020 07:44 PM
nanotech
10-02-2015 05:02 AM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: Wrieless reverse/backup camera wiring advice
