Remove Bose amp & bridge wires ?
2004 Tourist with Bose system . . .
Has anyone removed the Bose amp and bridged the wires?
I was thinking about installing an aftermarket system BUT still using the factory wiring. I would put an JL amp upstream from the bridged connections. My thought is that it would save me from running new wires to the (new) speakers.
Has this been done ?
Administrator
So you're just wanting to cut the speaker wires from the amp, then splice them together? And....add an after market amp on to those existing wires? I don't see a problem. ..
youll have to splice into the wires from the amp.. and even so the amp has some kind of digital turn on thing, i dont remember exactly whats the deal with it but i know you cant just wire power to it, and you cant use the wires at the head unit, its not that simple, you either have to buy the $100 something harness or you run new wire from the head unit to every speaker, which would cut out the amp... id advise taking it to the shop and pay them like $150 for the harness and to install it..
Administrator
^^I believe he's talking about taking the wires at the input of the amp and splicing to the wires coming of it and just leaving the amp where it sits(bypassing it). At least that's how I understood it...
yeah thats pretty much it, that way you dont have to re-run all the wire to the speakers, either that or splice 3 wires to keep them in the amp, a set to the head unit, and a set to the speakers, but i dont remember exactly but the shop said something about the amp recieving a digital signal to turn on, so you cant just run a power wire to it and expect it to turn on with acc. apparently it will cause a fire or cause it to pop, thats what they said, not me. i didnt know about the amp like that, i figured it was a standard amp and run a power to it, good thing i didnt..
My main goal would be to use the stock wiring to the speaker locations.
At this point, my plan is to remove the Bose amp, and install an amp in the glove box location.
I would then run RCA cables from a new Kenwood head unit to this new amp. Then I will run speaker wire from this new amp to the stock wires that currently exit the Bose amp.
The benefit of this would be that I would not need to install new speaker wires.
Master
Here's a place where you can get wire harnesses for 18.00 a lot better than cutting up the wires http://www.crutchfield.com/shopsearch/wire_harness.html
http://www.pac-audio.com/productDeta...&CategoryID=26
thats what you need, apparently its not as expensive as i thought i paid 150$ for that harness and for them to install the harness and have the radio working, which i already cut all the harnesses in the stock radio so thats where the bit extra came from..
yeah well the bose system is veryyyy complicated, even with all i know about it i would still say i MAY know 50% of whats to know about them, it would be veryyy easy to look stupid with these radio systems, ive already been there and just had to take it to a shop cause it made no sense at all... and im not too sure if theres many people that know much about it that are on here, i posted asking questions about it when i went to do my install and never really got any good answers. but after learning a bit about it i can see whyy
yeah then you will be fine, as long as you have 4 sets of rcas on the head unit, that way you can run them to both amps, i not you could splice the rcas you have but seems like extra work for something that is easily avoidable...
i think youll like the system though, i kept the bose amp in place with the stock speakers and put a 10" kicker l5 under te strut, it works realllly well, definitely am happy with it myself
350Z_Al
10-29-2020 07:44 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
