Subwoofer Question
Old 09-15-2014, 11:51 AM
  #41
NismoDude
NismoDude's Avatar
Originally Posted by RobinHood5
Were already completely removing the plastic so we can install the rear 6.5s. (You have to as I understand) And I don't have to do it I'm having my installer at the geek squad do it for me (for almost nothing cause of bestbuy employee discount.) so it's his problem.
Good on removing that rear panel to make access easier, especially if your installer has experience working on a 350Z.
However, I would recommend you consider either leaving the stock speakers and disconnecting them, or just removing them for weight savings, and NOT placing new speakers there.
Lots of threads on this.
The location of the stock behind the head speakers is a detriment to clear audiophile sound reproduction, being too close to the head, and a huge disparity in difference between how far left and right channels are from the listener. Having speakers there only serves to muddy the sound from your primary speakers (door 6.5 components), especially if you have high quality fronts.
You would be much better served with saving your money on those rear speaks, and going with a higher end component set of 6.5's for the front.
See my install:
https://my350z.com/forum/audio-and-v...ents-rock.html
Originally Posted by 92K1500
Rear speakers in this car are terrible. I yanked them out for weight reduction. They are pointless if you have good fronts.
And it's so easy to take the panel off it's pointless to try to get that plate off without removing it first.
This.
Old 09-15-2014, 12:16 PM
  #42
92K1500
92K1500's Avatar
I like my Rainbows up front. Sound great and they can still make your ears ring if you listen to it full tilt.
Old 09-15-2014, 03:10 PM
  #43
RobinHood5
RobinHood5's Avatar
Since I already have them I will have him install them but I will prob keep the sound all the way to the front or close. I went coaxial for simplicity but I went with kickers nicer ks series ones.
Old 09-15-2014, 05:01 PM
  #44
NismoDude
NismoDude's Avatar
What kind of speakers are you putting in the front?
I would advise you to reconsider wasting resources on those rear speakers, and if you haven't already, get a nice set of component speakers for the door......
Old 09-16-2014, 02:40 AM
  #45
RobinHood5
RobinHood5's Avatar
I've already purchased 2 pairs of kicker KS Coaxals (I only paid $48 a pair)
Amazon.com : Kicker KS65 6.5" 195Watts Coaxial Speakers : Vehicle Speakers : Car Electronics Amazon.com : Kicker KS65 6.5" 195Watts Coaxial Speakers : Vehicle Speakers : Car Electronics
What is the big difference between Coaxals and components anyway?
Old 09-16-2014, 06:30 AM
  #46
jdmfetish
jdmfetish's Avatar
waste to put speakers in rear
next time you go to a concert
turn your back toward the stage
same thing your doing
Old 09-18-2014, 07:53 AM
  #47
RobinHood5
RobinHood5's Avatar
Doing the install tomorrow! Can't Wait!
Old 09-18-2014, 07:55 AM
  #48
Syner
Syner's Avatar
post pics when you're done.
  #49
RobinHood5
RobinHood5's Avatar
Any ideas as to where/how the bass control **** should be mounted?
Old 09-18-2014, 07:56 AM
  #50
RobinHood5
RobinHood5's Avatar
Will Do
Old 09-19-2014, 08:49 PM
  #51
RobinHood5
RobinHood5's Avatar
The install is done! Brandon, our auto tech installer and Xavier the trainee did a phenomenal job at it and it sounds phenomenal! The box fit PERFECTLY. I left the padded mat in it to keep the not padded sub box from rattling (I didn't end up putting dampening material on it) and brandon custom made some brackets to strap it to the top. I'll hopefully post some photos tomorrow evening (Just got off of work tonight and work all day tomorrow). The entire build ended up costing right at about $730 with my employee discount/accommodations. The hardware cost $550 (Normally just over $1150) and the install cost me $180 (Normally just under $600). I think I waaaaaay more than my money's worth in this and am extremely happy with it.
I did go ahead and install the rear speakers but I have the balance turned significantly towards the front as it does sound better than 50/50.
The specific head unit (http://www.crutchfield.com/p_130X720...FH-X720BT.html) has a specific color already set as one of the defaults that perfectly matches the orange in the rest of the car.
The alpine power pack seems to keep up pretty well and sounds ok.
The panel covering the subwoofer is giving me some rattling so I'm prob going to be getting some sound dampening material for it.
I am going to use two of the unused 6.5" speaker grills for the cover over the sub, I'm going to cut some 6.5 inch holes and put them over them. just to let some air in.
One question I do have is how worried do I have to be about blowing this sub out. It's a 600w RMS 1200w peak, my amp is only 400w RMS idk peak. Just while I was changing some EQ settings tonight I found a "super bass" preset that sounded amazing but I'm wondering what the chances of blowing my sub are if I'm pumping that much bass through a single 10".
Will post pics and vids tomorrow or the day after depending on when I get the chance! Thank you all for your help in making this an enjoyable experience!
Old 09-22-2014, 12:56 PM
  #52
RobinHood5
RobinHood5's Avatar
heres some pics of the install and finished product
07-10-2022 07:44 AM
issyz
07-02-2017 03:04 PM
Alexreyes
09-30-2015 11:30 PM
Quick Reply: Subwoofer Question
