PAC-OEM vs Scosche SLC4
Old 09-29-2014, 02:25 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Arrow PAC-OEM vs Scosche SLC4
After 5 years of ownership I am finally upgrading my head unit. I had purchased a used PAC-OEM some time ago in anticipation of the upgrade but my order from Crutchfield includes a Scosche SLC4. So my questions are:
- do both of these units serve the same purpose?
- if so, which should I use?
I am only replacing the Bose head unit.
Old 12-17-2014, 09:49 AM
ryanmackk
ryanmackk's Avatar
Apparently the PAC OEM thing is for replacing the HU but keeping the Bose amp. That's my setup and I used PAC OEM to make it all work. I'm not sure about Scosche because it might be for using an aftermarket amp with a Bose HU. Go with PAC OEM just to be safe.
Moral of the story: F Bose up the as*
Old 12-17-2014, 09:52 AM
AdvanZ33
AdvanZ33's Avatar
That's what I ended up doing. Worked great until the amp started cutting out. Did the Bose amp fix and now I'm golden...for now at least
JEKL
08-26-2018 11:56 AM
revvenue
07-07-2010 10:39 PM
RedBullRR
01-25-2008 10:48 AM
Quick Reply: PAC-OEM vs Scosche SLC4
