gopro hero4 adhesive mounts (3m)
Retired Admin
I've seen people use the adhesive mount on exterior panels of cars before without problems. Personally, I wouldn't trust a tape/sticker to hold my camera so I either hard mount or suction mount. That being said, my GoPro hasn't fallen off my helmet, the only place I use the adhesive mount (that I'm actually reusing after applying it elsewhere twice).
Considering the dash isn't exactly a smooth surface, I'm surprised you expected flawless results. Did you prep the surface, securely apply the adhesive, and let it properly cure?
Wow, I definitely would not use it on the exterior, and yeah with the little bumps I didn't expect it to be perfect but I expected it to hold decently, it straight fell off when I unscrewed the piece to the mount.
And I believe I did a decent job, I cleaned the surface up (not with the wipes that make it all slick) then I stuck it on there and held it against it with decent pressure for a couple mins then let it sit for 24 hrs like it recommends.
I bought some loctite gel glue, I put a couple drops on the bottom of the adhesive mount (i don't plan on removing or selling the car so don't care if it leaves a spot) but seems to be working flawlessly now.
Retired Admin
Applying a little bit of heat during the curing process helps the adhesive backing become more malleable for uneven surfaces. Also, I'd clean the surface with some alcohol to get rid of any cleaning products that are on the mounting surface. Personally, I would have opted for hard mounting (so many options for this when it comes to GoPro) vs applying loctite to an adhesive. Just curious, where did you place the mount?
I actually decided against using heat cause it says to use a hair dryer to remove so I figured it would be a bad idea, also I used a dab of rubbing alcohol on a ragand wiped the surface, even though i haven't used anything in a couple months now. And i put it on the dash about an inch or two to the right of the center gauge cluster and about 3 inches above the ac vent, and yes I used the curved mount not the flat one lol, incase you were going to ask.
Maybe it was the dash surface, or maybe it was too cold while it was being put on.. or maybe its just hit or miss... I know I've seen a lot of mixed reviews for 3m so maybe it is just luck of the draw or some people go extra measures to have it stay on, who knows.
But you know my opinion on it. And after that I don't think I'd trust it for anything expensive or on the exterior of a car..
But your bike frame is probably a better surface then a rough plastic dash lol
Retired Admin
Like I said before, not sure what you were expecting when you applied the adhesive on a non-smooth surface like that but it is what it is. So any shots from the mounting point/angle?
https://www.youtube.com/channel/UCpl...7IYHk3w/videos
got some vids up now, more are uploading... dear lord does it take forever to upload a vid to youtube :O
Retired Admin
Mounting location/hardware should be dictated by what you're trying to capture. Regardless, the suction mount should allow for more versatility.
I recommend you mount it outside the car if you're recording car activities, but if you're set on in-cabin then mount it as high as possible using the suction mount.
I usually like to watch other car videos/reviews for different mounting locations. Check out my YT channel for the angles that I've used:
https://www.youtube.com/user/3hree5ive0ero
I liked the cam by the wheel then just above the drivers door ( I've seen both positions before) I just don't think I want to trust it. After my experience with the adhesive mount and my previous experience with suction cups, given the gopro suction cip looks heavy duty I don't think I could put it outside, if it fell off I'd be sooo raged lol. But the position you had in the cabin is what I'm trying to go for.
What om trying to get is somewhere in cabin that you can also see beside me. This seems about impossible though.
Have you put it on the strut bar? I would think the image ouside the windshield would be almost non existant at that point though..
Btw you tore it upp at PCA event 3!! That was inspirational lol.
Retired Admin
That view you're referencing was from the headrest mount. Never tried mounting on rear strut bar but I've tried rear window (with diff camera so can't really compare) and found it was pointless since you couldn't really see much out of the windshield. And any closer to the windshield would probably be a safety risk since I can already hit the camera with my helmet where it sits (center of car pretty much) with my headrest mount, which is also another reason why I tend not to use it. I guess if you had no passenger, you could make a T-shape headrest mount so the GoPro can be mounted where a passenger's head would normally be.
The GoPro suction cups are pretty stout and can handle most amateur motorsport activity you'll do so I wouldn't worry about mounting it outside. Plus, there are aftermarket mounts that are beefier if you need.
Any way you could take a pic so I could see how that mount is set up?
And the passenger mount would be a great idea but most my videos I have someone there, so I don't see that being used often..
A lot of my videos are from me driving around and stuff on streets, don't know if I'd get hassled with the go pro outside the car (probably not, but some cops are a holes)
I think a view from the position of that headrest mount would probably be the most ideal for what I want.
