Pac steering wheel interface and Wire harness, new HU
Hello everyone. I got a new pioneer HU with the metra wire harness and the pac steering interface. There are a few wires that i dont know what to connect them to if anything at all.
From the aftermarket radio harness, there is
1.orange/white (illumination)
2.purple/white (reverse gear signal input)
3.light green (Parking brake)
and on my metra wire harness adapter there is
1. Solid blue (power antenna)
2. orange (illumination)
i dont know where to connect these 5 wires. I'm assuming the 2 illuminations connect together like all the same color wires, but do they connect to the red or yellow power wires to get the electricity to perform the illumination? Also, do i need to connect the power antenna wire? What about the reverse gear input or the parking brake wire? I got all the other wires down, just these 5.
Could some one just break it down how I'm supposed to connect those wires and to what?
08, non-bose, non-navi
Pioneer AVH-X1700S
Metra harness 70-7550
Pioneer AVH-X1700S
The illuminations go together.
The purple white just needs to be tied in to the wire that controls your reverse lights coming on. Not very important if you don't plan on installing a backup camera (its to let your unit know when you put the car in reverse, so it can switch to the camera)
The parking brake one just needs to either be hooked up to your parking brake wire or to a good ground. This is only if you plan on watching movies or something on your unit. As a safety measure it will only play with the parking break engaged. Although directly grounding it is supposed to bypass that.
