Aftermarket HU with orig. BOSE amp
Old 08-19-2015, 02:31 AM
Zeratulcz
Zeratulcz's Avatar
Default Aftermarket HU with orig. BOSE amp
Hello,
I am now install new audio head unit into my 350Z.
My new HU is Pioneer SPH-DA120 with preamp RCA outputs.
I do connect HU RCA outputs into BOSE amplifier input.
He plays it very quietly. I have to give volume to maximum, so it played a normal volume.
It is possible to connect the power amplifier into the speaker outputs on HU? Consequently reduce output power with resistors?
Thank
Best Regards
Zeratul
Old 09-20-2016, 04:27 AM
sflogerzi
sflogerzi's Avatar
Since the Bose Amp uses balanced differential inputs your aftermarket headunit will need to go through a converter. I used Rockford Fosgate RF‑BLD . You will need 2 of these, 1 for the fronts and 1 for the rears. These Line output converters will give you full volume and they sound great.
Old 09-20-2016, 04:42 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
OP hasnt logged on in over a year.... but this may help someone else
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
350z82
10-01-2015 06:25 PM
SharX59
09-27-2015 09:23 AM
Quick Reply: Aftermarket HU with orig. BOSE amp
