question about vented enclosure
Old 02-17-2016, 05:35 PM
shadowm891
shadowm891's Avatar
Default question about vented enclosure
Is it even possible to build a vented enclosure for a single 10 under the strut bar with mdf wood tune at like 33-36hz ?. The reason i'm asking this question is i have a single 10 inch jl audio 10w6v3 in a zenclosure witch is .75 cubic foot. And after hearing the sub in a 1 cubic foot vented enclosure tune at 33hz i was blown away how good it sound. So now i am stuck on wanting a vented enclosure for my sub and i would like to keep it under the strut bar if possible to save a little space.
Old 02-18-2016, 12:16 PM
jdmfetish
jdmfetish's Avatar
a bit difficult in your required location
but ported kills
sealed is wack
i am using 3 x 8" ported at 32 hertz now , but i have no ability to put a can of soda in my hatch area now
Old 02-18-2016, 12:53 PM
JMII
JMII's Avatar
Lightbulb
Originally Posted by jdmfetish
but ported kills
sealed is wack
Your opinion.
As mentioned one of the downsides to ported designs is the space requirements. That is why I generally avoid them in car audio applications. However I run ported in my home audio setup.
To the OP: if you expanded the box to occupy some of the area between the bulkhead and strut tower I'm sure it could be done.
Old 02-18-2016, 02:49 PM
shadowm891
shadowm891's Avatar
yea i don't mind giving up the space behind it as long as i get to keep the space in front of it. from what i have read i know jl audio ask for a .75 cubic foot box tune at 39hz but the box i was thinking about building if i can would be 1 cubic feet with the option to change out port's if need to like 39hz down to 35hz which ever sounds best. but if all worst comes to shove i'll do .75 cubic foot.
Old 02-19-2016, 05:41 AM
jdmfetish
jdmfetish's Avatar
aero ports and or PSP ports will allow you to change frequency easy
Old 02-19-2016, 08:30 AM
JMII
JMII's Avatar
Play with your volume and ports using WinISD:
http://www.linearteam.dk/default.aspx?pageid=winisd
Old 02-28-2016, 09:36 AM
shadowm891
shadowm891's Avatar
well after a little help from a friend of mine who is great with math we were able to make a vented enclosure under the strut bar.
aaronsaya
Tuning
19
05-31-2016 11:05 AM
R6n350GT
05-30-2016 11:20 PM
zachary.newsom
02-15-2016 04:14 PM
Zee Dirty Tree
02-15-2016 11:02 AM
liqalu04
02-14-2016 01:16 PM
Quick Reply: question about vented enclosure
