Rear speakers?
Old 05-01-2016, 07:17 AM
Z33E
Z33E's Avatar
Unhappy Rear speakers?
Hey guys I have an 04 350z base model no Bose no nothing, and I was wondering if the speaker pods behind the head rests have speakers in them because I hear no sound coming out of them. I did a new radio install and checked all my connections so that rules that out of the equation so I was wondering if they're dead, and if so if that's common. And also wondering if there even are speakers in there being they are base model with literally nothing.
Old 05-01-2016, 08:47 AM
dcains
dcains's Avatar
Speakers should be there regardless of trim level, but that doesn't mean someone didn't pull them out, or that they're blown.
Old 05-01-2016, 03:16 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
You should have speakers in their but a lot can happen in 12 years.
Old 05-02-2016, 03:07 AM
92K1500
92K1500's Avatar
The rear speakers ruin your soundstage anyways. I pulled mine out years ago and have been happy ever since.
Old 05-02-2016, 08:34 AM
CK_32
CK_32's Avatar
They are in there. Something aint right tho.
Id say connections but you say you traced it. Idk maybe a blown fuse? You check that yet? Did you check also test the radio connection/output?
Old 05-02-2016, 08:57 AM
dboyzalter
dboyzalter's Avatar
Rear speaker fuse that would be one crazy fuse box
Old 05-02-2016, 10:46 AM
CK_32
CK_32's Avatar
Who said the fuse was speaker specific. If he has a blown fuse to block current to the sound system or accessory that could be a problem... Not uncommon after install of aftermarket radios or electronics. Also not all fuses are in the fuse box. Many accessories have direct wire fuses built in dependent on application.
Old 05-02-2016, 01:45 PM
92K1500
92K1500's Avatar
I've never seen a fuse on a speaker wire in my 11 years of doing audio.
Old 05-02-2016, 02:24 PM
dcains
dcains's Avatar
Either the speakers are absent, the wiring is disconnected/cut, or the output from the headunit is dead. I lost one of the rear channels on my OEM headunit, so it happens.
Old 05-02-2016, 02:37 PM
92K1500
92K1500's Avatar
It's been so long I don't remember what it was, but I do remember something in my stock BLOSE head unit wasn't working right and if I hit the side of the console fairly hard it would make it work like it was supposed to.
Old 05-02-2016, 02:38 PM
dcains
dcains's Avatar
The OP doesn't have the Blose system, so there are no external components to cause trouble.
Old 05-02-2016, 02:53 PM
Z33E
Z33E's Avatar
Is there a way to check the inside of the pods without all that BS disassembly of all the other panels inside near it aka by the door and all that
Old 05-02-2016, 07:08 PM
dcains
dcains's Avatar
Not unless you have any friends with x-ray vision.
Old 05-02-2016, 07:39 PM
VO...
Administrator
VO...'s Avatar
Received 2,747 Likes on 1,836 Posts
This...
Old 05-04-2016, 05:55 PM
CK_32
CK_32's Avatar
Then you must do some nice cars... You would be surprised as some of this bubbad stuff Ive found on cars and Walmart/Autozone "upgrades" on some of the cars me and my friends have picked up.
Ive seen some ghetto rigs to say the least lol
Old 05-04-2016, 06:19 PM
Spike100
Spike100's Avatar
I agree.
No… There is NEVER a fuse on a speaker wire that does anything. That is Bogus.
Misaka_10032
01-27-2019 01:36 PM
ZROCM
Suspension
05-13-2016 07:53 AM
uzclutch23
05-06-2016 01:29 PM
r350k5
05-05-2016 05:34 AM
NR350z
04-30-2016 04:27 AM
Quick Reply: Rear speakers?
