Sub help
Old 09-08-2016, 07:27 AM
JAPZILLA
JAPZILLA's Avatar
Question Sub help
I just got around to upgrading from stock system, and got
-a pair of Polk db652's (with an amp to power them)
-a Kicker 40CWRT101 (10")
-and a pioneer GM-D8601 to power the sub.
I got all of it installed at Car toys. The sub is in the factory location, and when turned up, it rattles the frame it is in, and hits hard, but not nearly as hard as it should. It is a good kicker, and the amp meets its RMS needs (+ 50%), and the sub has a pretty high sensitivity and low bottom frequency. It should be rattling my bones, but instead is just rattling behind me. I don't know if this is because it needs a bigger enclosure, or I need to deaden the inside.
What should I do to bring the sub to its potential? and should I use Dynamat, or something else? Thanks, and sorry if I sound dumb
Old 09-08-2016, 08:08 AM
jdmfetish
jdmfetish's Avatar
stock location is not an enclosure
so its not in an enclosure now
Old 09-08-2016, 08:12 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
you essentially have a free air mounting... that is all the stock location is
Old 09-08-2016, 08:17 AM
JAPZILLA
JAPZILLA's Avatar
really? Haha I am very new to audio and I really dont know much... or anything about car audio. What can I do to make this work?
Old 09-08-2016, 08:19 AM
travlee
Master
travlee's Avatar
have a real box built, or buy one, that goes under the rear strut bar
Old 09-08-2016, 08:25 AM
JAPZILLA
JAPZILLA's Avatar
I do wish that were an option... but I have a roadster. I keep regretting getting the roadster.
Old 09-08-2016, 08:29 AM
travlee
Master
travlee's Avatar
oooooh, ya not many choices
JAPZILLA (09-08-2016)
Old 09-08-2016, 08:36 AM
JAPZILLA
JAPZILLA's Avatar
Thanks for your input
Old 09-08-2016, 11:48 AM
JMII
JMII's Avatar
Build a box with an 8" or 10" that fires out thru the factory opening. As mentioned above currently the sub is not in a box or enclosure. There are solutions available but all of them I've seen fire the sub down which is just going to generate rattles like crazy. I really wish one of these fiberglass sub box makers would just take their current design and modify it for a front firing 10", hopefully a setup that completely replaces the stock sub frame and grill since those rattle too even after dynamatting.
Old 09-08-2016, 03:52 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Put that bump in the trunk... I dont know about thr roadster or how much room you have in your cubby but im sure if your motivated you could seal up that space and make it work...
Tape fiberglass and great stuff could probably make a decent home in their.
Old 09-08-2016, 06:50 PM
dcains
dcains's Avatar
You can build a box from 3/4" MDF that will fit inside the area where the original sub was. iIRC you can make it 18" x 12.5" x 6.5". I have a thread in the audio section about the one I built and how the amp is mounted. Search for it.
Old 09-13-2016, 04:43 PM
shyun1250
shyun1250's Avatar
There's also a company that builds an enclosure that fits with a 10" JL sub or a 13" shallow JL sub in the stock location.
Might want to search around a bit for it.
I can't seem to recall which site it was. sorry
EDIT: Wickedcas makes it.
http://www.wickedcas.com/product.php...8&bestseller=Y
Old 09-13-2016, 08:25 PM
dcains
dcains's Avatar
So does SRQ:
http://srqcustoms.com/shop/vehicle-m...nd-front-seat/
Heard one, and it was nothing but rattles.
Old 09-19-2016, 01:03 PM
JMII
JMII's Avatar
Lightbulb
Originally Posted by dcains
So does SRQ... Heard one, and it was nothing but rattles.
Owned one, can confirm: rattle city. You are pressurizing air in a thin metal box covered by snapped on random bits of plastic.
You need to pressurize the air in the car, this means a front firing sub. The hard part is building a box that fits the glove area and at the same time completely seals it off. Wicked just needs to make that down firing box into a front firing one and the problem is solved. Given the space this might require having only an 8" sub but I'd rather have one clean 8" then a sloppy 12".
Old 09-19-2016, 01:39 PM
dboyzalter
dboyzalter's Avatar
I had a single 8 in the back hatch area, it was a pretty mint set-up untill I decided to go full retard.
Old 09-20-2016, 11:01 AM
jdmfetish
jdmfetish's Avatar
pics or it didn't happen
Old 09-20-2016, 01:55 PM
dcains
dcains's Avatar
This is the one I built for the original sub enclosure. Very solid, airtight, properly-damped, and the correct size. Getting all the details right makes a big difference.
TBDesigns
10-30-2007 06:10 PM
Dream350Z
01-06-2006 09:20 PM
Hammer1
01-08-2005 03:50 PM
roydiculous
09-09-2004 04:02 PM
Quick Reply: Sub help
