High-End Audio Build Complete!!! (McIntosh, Morel, Seas Lotus Inside)
#41
on
Originally Posted by 16psibrick
now you should have ran all seas lotus for hte front stage
Or a BRAX MATRIX 3-way......
i heard them once with a set of audio control EQX compared to those Rainbow refrence 2-ways
BRAX FTW!!!!!!!!!!!!
Kwame keep up the good work
#46
Speed of White
on
Originally Posted by kwame@z1
Thanks for the support guys.
I went in to the stereo shop today and it looks like I will be installing both of the 12" subs I purchased, one in each rear corner of the hatch. I am now even more excited to here this thing once it is done.
#47
on
Kwame ... bro
Nice install. Very sorry we couldn't get it to work out for ya ... I'd have gotten you on the website with this kind of work
The Loti will be all you'll ever need in terms of SPL and headroom.
Excellent work and keep us posted bro.
-jim
-jim
#48
on
Originally Posted by DVFlyer
Looking forward to this part. I'm in "upgrade my sub" mode. One 10" is nice, but I need more low end.... Two 12's (or one IDMAX12) were suggested, but I'm having trouble figuring how to install them without using much interior space.
#50
Originally Posted by JimRHIT
Kwame ... bro
-jim
-jim
Thanks for the kind words. I told you inititally that I was not holding back on the install with this car. When everything is all said and done with my Z I want to be able to say that at no point in time did I cut any corners with the build up of this car.
I wish I was able to use the sub you recommended but we both know how that ended up. It would have been pretty cool to have made in on the website but unforunately now that is not possible.
I agree on the fact that the two Loti will be more than enough regardless if they are known for SQ or not. Two 12" quality subs should sould awesome regardless of what brand in such a small car. The fact that I am feeding them clean power and they are one of the most musical subs you can get should compliment my front stage and add to overall dynamics of the sound system.
Next time your in NY you might have to look me up so you can check out everything in person, you have helped me out a lot in this whole process and I appreciate it.
By the way if anyone is wondering the panel is not leather it is vinyl, I think I mentioned that earlier.
Kwame
#51
on
that does look prettygood...but the only thing is....the speaker grills look a bit ...blahh, but the the job looks flawless man...good stuff ....can't wait to see what else you got in store for the Z....where is ROB with his kind words?....lol
#52
#53
on
lol...c'mon...don't get all upset...I can really appreciate what you're doing...
it's quality work man...I was giving my input that's all..it was minor...
by the way...are ther any Takata ramps Available at Z1?...
#54
Takata no longer makes ramps.
#55
Simplicity in Sound
Simplicity in Sound
Hay Kwame,
first of all, looks GREAT My only objection would be that this isnt the ideal locations of imaging, but aside from that, the freq response, the staging, all should be very nice. My only other slight issue is that i wish they molded the door so the midbass mold came out just a tab more on tyhe bottom as to make a perfect edge against the armrest front portion. but i thin mthis is osmehting MUCH more noticable in pics than not.
great works, great craftsmanship! kudos! cant wait to see the rest of the install
b
oh and i always liked morel grills, i will never call anyhting on it since our own DLS grilles arent kinda...unusual, though i sometimes wish they would make the grille so its protecting the entire speaker, this isnt much of an issue with door mounts, but in the past, hwen i have done kicks with more, i get more than my share of dirt and gtrime into it
b
#56
on
Don't know if it is not finished yet or what ... but it looks like the factory grilles are still in place in front of the tweeter. If that is the case, change that right away. That'll really hurt your tweeter performance and totally mess up the tonal balance of the system. Besides .. you gotta show of those pretty tweets
If I am wrong ... well ... I'm on my way to get a coffee ... its b/c I am not awake.
#57
Hay Kwame,
b
b
#58
on
Because the tweeter is basically behind a mask.
Think of talking to someone .. now hold your hand in front of your mouth and talk to them .... insertion loss.
The "factory" grill or guard is voiced into the system by the engineer ... and it is intended to be listened to with that permagrill on there ... however, when you put a tweeter behind that grill and don't compensate for it ... things get out of whack.
It also affects the dispersion charateristics of it too ... not that you are moving your head all the time listening, but still .... its a problem to SQ guys.
Its much harder to tell or hear with tweeters ... but its something that I'm gonna nag you to fix. Try it this way ... stick them on the factory panels in a lump of clay just to hold them there ... and listen. Now stick them behind the grilles and listen .... if you think it sounds better or different .. make your decision from there.
jim
jim
