Audio Builds Audio projects and builds from my350z members
New Installed DDX8019 W/LZ702W Touchscreen
Old 06-06-2008, 06:25 PM
  #101
ncparamedic
Prodigal Son
ncparamedic's Avatar
The bad thing is i already bought the L702 monitor. Got it new for about $200. What i will do is buy a 07 cubby and take it to a fabricator and see what can be done. The worst i will be out is a few hundred. A price to pay to help others..lol..Im sure there is some way to do this..
But i will have to wait a month. I really wanted to do the portal setup. Though a little more expensive, much better control.
Ill let you know what happens, or if you learn something before then let us know
Old 06-06-2008, 08:21 PM
  #102
Spike100
Spike100's Avatar
^^ The first person installing an aftermarket 7” monitor into the upper/forward cubby of a 2006 and beyond Z model becomes a legend and “rock star.”
Many have asked about/for this… but no one has done it (at least no one that I’ve seen).
--Spike
Old 06-06-2008, 09:28 PM
  #103
Kal_El
Kal_El's Avatar
Good luck man, I hope it turns out well.
Old 06-17-2008, 01:51 PM
  #104
niles08
niles08's Avatar
Default about the '06 and beyond cubby!
Hey Everyone... I was doing research & there is a company that sells the cubby with the retractable face... I have not personally tried it yet, but the set up is similar to the '03. From this, you should be able to mount the 7" screen and set it up similar to the older Z models. The website for the cubby is...
http://www.courtesyparts.com/Merchan...de=68250-Z3306
Hope that helps!
Old 07-10-2008, 11:23 PM
  #105
B5I8
B5I8's Avatar
Will this work if I have an 05 with nav (screen was removed but motorized door still works) or do I need the crappier 03 cubby (non-motorized door)? It basically looks the same from the outside. I already have a DDX8019 as well as the KNA-G510 and a Boyo reverse camera, I was looking to add the LZ-702W to display the nav as well as the reverse camera. I don't need it to display anything else, but I do want the audio for the nav to output through my system, is that possible? Would I need to buy anything else to make this work how I want it?
Old 07-11-2008, 08:03 PM
  #106
Spike100
Spike100's Avatar
You can put the Kenwood LZ-702W LCD Touch Screen into your current arrangement (the upper/forward cubby). You may need to do some minor custom fabrication, but that is a simple and an inexpensive modification.
Since you have the KNA-G510, it’s just as simple as connecting this to the Kenwood LZ-702W’s hideaway box. You can also connect your rearview camera to the Kenwood LZ-702W’s hideaway box. There is a setup you run to have the rearview camera display its image automatically when connected to the reverse gear sensor, or you can use it manually by pressing on the LZ-702W LCD Touch Screen.
The KNA-G510 navigation black box provides a muting signal to H/U’s supporting this feature. I believe your DDX8019 does support muting, so you’re good here. You connect the A/V output on your LZ-702W’s hideaway box to the AUX input on your DDX8019 for automatic muting of the current output (radio, CD, etc.), switch to voice guidance from the KNA-G510 (broadcasting through your car’s speakers), and back to the current output after the voice command is issued.
I think I have this right, but if I am wrong, hopefully someone will post a correction.
--Spike
Old 07-11-2008, 08:58 PM
  #107
B5I8
B5I8's Avatar
I figured it'd something like that. I know that on the DDX8019 you can either use the cable made for the nav or you can configure it so that it thinks it's a 3rd party nav where you would plug it in to AV1 input. I was just wondering if by doing that it would automatically mute whatever's playing to hear the nav. Thanks.
Old 08-23-2008, 09:05 PM
  #108
daburch
daburch's Avatar
Default Stock Nav and DDX-8019
I installed the DDX-8019 myself, a huge job, with a lot of help from the info in these forums. I have it unning through the Bose amp and speakers, sounds pretty good. I even accomplished what is reportedly impossible, playing the stock nav voice through the sound system. I'm surprised that with the level of thought that went into a lot of these posts it hasn't been done before. I do have a couple questions though:
1) How do you get album Art to show when playing off USB? Is there a specific file format, size or name that must be used? I can't find anything on this in the manual or the Kenwood site.
2) I don't receive any radio signal. Is there something special I have to do with the Antenna or it's amp?
Old 10-10-2008, 05:53 PM
  #109
zaid990
zaid990's Avatar
hey dude where did u buy the DDX8019 from??? cuz crutchfiield says that it is discontinued.....and can u hook up a gps to the DDX8019 or do you have to have the second screen in the cubby.....u should make a DIY guide...that would be pimpin
Old 12-03-2008, 12:48 PM
  #110
huntdogg
huntdogg's Avatar
--Spike
I wanna be this rock star...
Old 12-03-2008, 03:36 PM
  #111
Sandy@ART
Sandy@ART's Avatar
I have an extra 06+ cubby if someone wants it to play around with..
Old 12-03-2008, 03:37 PM
  #112
Sandy@ART
Sandy@ART's Avatar
Look on ebay..plenty of vendors selling them..
Old 12-03-2008, 05:35 PM
  #113
Spike100
Spike100's Avatar
--Spike
You can be the star. Just do it… a good explanation… and lots of pics.
Your thread will have 10 or more pages of replies and 10K views. Go for it.
--Spike
Old 12-03-2008, 06:13 PM
  #114
Sandy@ART
Sandy@ART's Avatar
+1..i wonder if this will be the same issue with the 370??
Old 12-03-2008, 06:22 PM
  #115
Spike100
Spike100's Avatar
^^ Good point, and yes it will.
The good thing is a professional installer will be able to provide the installation and custom fabrication for a very reasonable price. It will probably be much less $$ than buying the OEM system, and the aftermarket will provide better "everything."
--Spike
Old 12-03-2008, 08:21 PM
  #116
Sandy@ART
Sandy@ART's Avatar
Looks like someone did the converstion on an 08..look what i found on ebay. Look through the pics..
http://cgi.ebay.com/ebaymotors/Cars-...3A1|240%3A1318
Old 12-04-2008, 05:08 AM
  #117
huntdogg
huntdogg's Avatar
--Spike
Need the parts first. Still looking for a good deal on the screen.
Old 12-04-2008, 05:13 AM
  #118
huntdogg
huntdogg's Avatar
I'm wondering how involved a retrofit to an 07 would be...
Old 12-04-2008, 05:18 AM
  #119
Sandy@ART
Sandy@ART's Avatar
The 06+ cubby will fit 06-08. Prior cubbys will not fit the 06+ ..
Old 12-04-2008, 09:25 AM
  #120
huntdogg
huntdogg's Avatar
in that case, pm me with how much you'd be looking to sell yours for.
Quick Reply: New Installed DDX8019 W/LZ702W Touchscreen
