VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
#101
on
Originally Posted by vo7848
"underpowering a sub causes more damage than over powering it".
#102
Wouldn't running 500watts rms into a FI Q series severly underpower it? I believe it was said that "underpowering a sub causes more damage than over powering it".
you can clip if you under powering
if he sets his gain 1/2 way on the amp he won't clip
#103
Administrator
Originally Posted by 350zspl
i prefer more power than less
VO(not able to add 2 + 2 and get 5)
#104
on
So theoretically a 500 watt amp turned up half way outputs 250watts. If the sub can handle 1000watts rms, how is this not underpowering it?
Let's put it this way:
If you have a clean audiophile grade headunit putting out 8volt on the premaps, you have a JL audio 1000/1 amp, and a subwoofer that is rated at 1000 watts rms, and everything is tuned to put out 1000 watts without clipping. This is the perfect match of equipment when it is tuned properly. Now if the headunit's volume **** is turned up only half way and you measured the watts coming from the amp you would most likely get a reading of around 500 watts, not 1000 watts. So just by turning down the volume you are 'underpowering' the sub. Is it causing damage? Not at all, it's just not as loud as it can play.
Now, same scenario as above but with a 500/1 amp instead, and everything is tuned to put out 500 watts without clipping. You turn the volume up all the way on the headunit and you are maxing out at 500 watts from the amp and you say to yourself "i know this sub can be louder, let me crank up the gain on the amp to make it louder", this is now going to cause the signal to clip which will cause thermal damage to the driver and thereby cause premature failure most likely.
#105
Administrator
Originally Posted by StreetOC192
It's not really as simple as this. There are so many factors to take into account when figuring out how much power will be output at a certain gain level. output voltage of the headunit, input voltage range of the amp, the cleanliness of the source (cd, ipod, radio, etc), position of the volume **** on the headunit.
#106
on
Gotcha. So it is better to tune one's system with the HU at max output rather than the amp?
Turn the amp gains down all the way
Turn volume on headunit to 3/4 (leaves room for lower output sources)
Use a CD with test tones (usually higher output than FM radio or iPod)
Slowly turn up gains on amp
On mids/highs turn up until you hear clipping, then back off a hair
Subs is hard to hear clipping, but sometimes you can increase the xover point to around 150Hz and you can usually hear when it clips.
Or you can:
Use a multimeter and measure the voltage on the output of the amp
Slowly turn up gains on amp until you reach the target voltage given by this calculator HERE: http://www.subwoofertools.com/forum/setgain.asp
You want to adjust gains with no loudness, no EQ adjustments, no srs circle surround, etc. just raw audio. All of these adjustments can be made after you have set your gains properly.
#107
Administrator
When I tune my systems, i:
Example: If the numbers on my HU go up to 100, I should turn it down to 75?
#108
on
I like this option. One question though. When you say turn the HU gain up 3/4, so you mean to literally turn the volume up until it won't go any higher then back off 1/4?
One question here also. By no eq adjustments, do you mean bass, mid, & high should all be set to "0" or to the least negative setting they will go to? I believe my HU ranges from -6 thru +6, 0 being the mid point.
#109
Administrator
Yes, this leaves you a little bit of play to turn up some quieter sources or recordings.
set the bass and treble and mid tone to "0", turn off loudness, turn off any sound enhancement features, set any equalizer settings to "0".
What able the variable "bass ****" that links to most sub amps? My RF P8002 has a bass **** interfaced to it via and RJ45 cord. I use it to turn up the bass when a song lacks bass, instead of turning it up on the HU. It's much more convienient to make quick adjustments when a song is playing.
Should this **** be at mid level also, when tweeking the system?
#110
on
Thank you graciously for the info. It appears I've been tweeking incorrect all along.
#111
Administrator
Bass ***** are nothing more than gain adjustments from a remote location, but the max position of the remote **** will basically be the setting that the amp gain is at on the amp chassis. Disconnect any remote bass ***** prior to tuning the amp. Once the amp is tuned, connect the remote bass ****.
#112
higher gains means your reaching peak volume sooner on your head units volume ****
lower gains allows you to get to the same volume just farther down the Hu volume ****
#113
#114
on
1 Post
Luckily, my amp has a remote gain ****.
#115
on
Originally Posted by blasian
I thought bass ***** weren't gain ***** but just a boost for a certain frequency? eD has a video on their site on why they don't recommending using bass *****.
The Amps with ***** that I have owned in the past, the ***** were nothing more than a gain adjustment. When turned all the way down, the sub was basically turned off (gain set to minimum), most recently the last amp I had with such a **** was Crossfire's VR705d. Crossfire describes it as a "Remote Subwoofer Level Control ****".
Please make sure you know what your specific **** does.
On a side note, I don't like bass ***** either. If the system is tuned correctly what is the purpose of a bass ****?
#116
Administrator
When turned all the way down, the sub was basically turned off (gains set to minimum),
Should I still unplug it when tweeking?
#117
Administrator
a gain is not a volume ****
#118
on
When my bass **** is turned all the way down, the bass still plays. If I'm playing a song that was recorded with low volume and I need more bass, all I have to do is turn the **** to the desired volume and my sub gets louder...
So if is it 0to+10dB - turn it all the way down
if is it -10to+10dB - turn it to the center
Your overall goal is to have no physical or electronic modification of the signal when setting gains.
#119
Administrator
If it's a boost at a specific frequency, read the specs, it should tell you if this boost level is something like 0to+10dB or something like -10to+10dB, you want this set to 0.
